Amp running hot
ralphwiggum
Hey guys whats up,
I have a boss blade blx4000 pushing two kicker cvr12's. The amp is running hot and shuts down after about 30 minutes. The people at circuit city set it up running at 1 ohm and im not sure if it should be? What should I do to help fix this problem? The people at circuit city also said that I would need dual 4 ohm voice coil subs in order to be compatible with my amp? Please help, thank you.
Post edited by ralphwiggum on
the amp has how shut down completely and i have no bass at all. please help.
Hi Ralph - welcome to the forums. You may have better luck trying the car audio part of the forum (as I assume you are refering to car stuff).
Sorry I can't help you anymore than that. :rolleyes:
Good luck.
ChrisHT Rig
Polk SDA SRS 2.3tl - Anthem 2 SE
Polk CSi5 - Adcom 555
Polk Monitor 30 - HK DPR1005
SVS PB12 ISD/2
Denon DCD-1500II
Sony SXRD 60"
ShengYa CS-10
Basement Rig
Polk SDA SRS2
Carver 1.5t
Carver C2
Technics SLD202
Some Other Sony DVD/CDP -
when u say shut down do u mean fried the amp if so then i hope u have a warranty ! i had a boss amp also the riot series and that amp got steaming hot but to my surprise never quit so my guess is its the wiring check the boss audio site to see the specs on what it can and cannot handle hope this helps.Whatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest.
