Power question please =(
EricSS
EricSS Posts: 5
edited September 2006 in Speakers
I am buying a CSi5, RTi10 fronts, and FXi3 rears. Ill prolly just get a 12"Dayton as a temp. sub.
After all this though I will be tight on cash. Anyone able to suggest a reciver that would be as cheap as possible, but not cheap enough to damage the speakers?
I was asking around on other forums if a dayton AVR-987 would be enough, and people told me it would prolly be to little and possibly cause damage to the speakers. (They say not enough power is worse that to much power).
Anyone care to help out a complete beginner?
Post edited by EricSS on
  • jhermance
    jhermance Posts: 214
    What price range are you looking to stay in? It will be easier to give you suggestions if you had a price in mind.
    Samsung UN46C7000
    Cambridge Audio 640R
    Sony BDP-S570
    Magnepan MMG's
    Totem Dreamcatcher Center
    Eleganza™ Bella 1200 High Performance Subwoofer
    Polk R15 Surrounds
    Audioquest Cables
    Panamax 5510-PRO AC Regenerator
    Monster Cable HTS 2500 MKII power cleaner
    Nordost Blue Heaven Interconnects
  • Early B.
    Early B. Posts: 7,900
    Tell you what -- first invest in a good receiver. This is an area where you don't want to skimp. If you don't have the money to buy everything at once, then concentrate on setting up a nice 2-channel system with a Hsu or SVS or comparable sub, then buy the center channel and rear speakers later on. Just be patient and do right the first time.
    "God grooves with tubes."
  • Lsi9
    Lsi9 Posts: 616
    from experiece he is right....start big yet small get the best you can get for 2 channels then upgrade over some time.
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • cfrizz
    cfrizz Posts: 13,415
    Welcome Eric. Plan on getting a receiver that has preamp outputs so that you can add separate amplification later on. Do a search here on the forum for receivers & separate amplification. You will learn a lot.
  • Ern Dog
    Ern Dog Posts: 2,237
    Agreed. Why have these kick **** speakers with a mediocre avr & sub. It will cost you more money doing it this way in the long run. Do it right the first time: AVR-Rti10-killer sub-center-rears. You won't regret it.
  • EricSS
    EricSS Posts: 5
    Well the reason I wanna get these speakers now is because at this time I can get a 60% discount on them.
    As far as a sub goes, I do want a SVS, but chances are I will have the sub turned as low in volume as it can go until I move next March, so the Sub isnt a thing I really need at the moment. I live in an apartment and all my Subs(Computer and HTIB) are always pretty much off, neighbors like to complain.
    So as far as the sub goes I think I would be fine without one until I can afford the best.
    Im just wondering about the power I need, lots of high end recivers dont seem to get close to what the speakers can handle.
    I know getting an Amp would be ideal, but what would hold me over till then. As far as RMS power goes.
    For example, the harman/kardon AVR-635 seems like it is good. It carries a price tag of $1300, but it only is giveing 75watt per channel. Is that going to be enough for speakers that can take 300?
    I dont know if Im looking at the specs in the correct fashion. How much money would one spend on a decent reciver? Obviously spend as much as you can afford, but I am trying to figure out how much Im going to have to spend.
    To me it looks like even the most high end recivers dont output enough power to make these babies run.
    I figured the Denon(I said Dayton in my ealier post, oops) AVR-987 would be enough at 110watts per channel. Guess not though? What if I added an AMP to this?
    How much would I be looking spend on a decent reciver?
  • Willow
    Willow Posts: 11,217
    One thing to keep in mind is that the specs are not created equally. Sure on company might say it's 100wpc when another says they put out 55wpc. I went from an 85wpc yamaha to a 65 wpc HK and the HK kicks major butt.
  • MattN03
    MattN03 Posts: 558
    That's the order I put together my H/T system. It took about 6 months, but it was worth it. BTW, the H/K 635 powered my RTi8's just fine before I added the Rotel amp.
  • danger boy
    danger boy Posts: 15,722
    buy a used receiver.. you'll save some $$ that way.
    PolkFest 2012, who's going>?
  • GATOR3000
    GATOR3000 Posts: 355
    +1..............buy used with preouts. Get the Rti10's and CSi5 first. You might get 60% off now, but it will cost you more in the long run. Do it right the first time and be happy. Besides you can listen to 2 channel right away and you will have HT without the surround for now. Add the surround and sub in 6 months when you move and be done with it.
    BTW, welcome to the club. This is an awesome forum!
    Gator:) :)
    Theatre System 5.1
    Sumsung HP-S5053 plasma
    Receiver Denon AVR 3806 Pre/Pro
    Parasound HCA 1500A amp (front L/R)
    Parasound HCA 1000A amp (centre)
    B & K AV5000 amp (bi-amp + surround)
    Dynaco ST70 tube amp (Herbie HAL-O9)
    polkaudio Lsi15 (Cherry) 2-channel
    polkaudio Rti8 Front (Cherry)
    polkaudio Csi5 Centre
    polkaudio Rti6 Surround
    polkaudio PSW1000 Subwoofer (Cherry)
    Original A8T CD
    Pioneer DV-275 DVD Player
    MONSTER CABLE MP-HTS3500MKII Powercentre
  • cfrizz
    Eric, there is no AVR that will put out all of the power that speakers can handle. That is what separate amplification is for.
    Just go & listen to a variety of receivers & pick the one that has all of the features you want in it (MOST ESPECIALLY PREAMP OUTPUTS!) and has a sound that you like.
    If possible, listen to them playing the RTI 10's.
  • EricSS
    EricSS Posts: 5
    One last question.
    Would something like THIS be ok. If I connected it to a good amp?
  • Willow
    You'd be laughing if you went that route. Heck you could even go for something a tad cheaper and spend the extra on a better amp.
  • cfrizz
    Eric, If you look at the Denon's 19xx & 21xx series, you will find basically the same machine for less money with preamp outputs. Hook it up to separate amplification & you are all set.
    Use the money that you save & put some more with it & get a 5-7 channel amp. Look at used Outlaws, Rotels, Parasounds, etc.
    Try to get a 200 wpc amp, that will show you the biggest improvement. You have great speakers & they deserve that much power.
  • EricSS
    EricSS Posts: 5
    Ok, this helps. I was thinking I needed a sweet reciver and a sweet amp. I am slowly understanding =)
  • cfrizz
    Think of the receiver as having all the bells & whistles that you want it to have, and the separate amp will take care of all the power requirements.
  • gonzalr
    gonzalr Posts: 92
    http://www.costco.com/Common/Category.aspx?cat=80&eCat=BC|79|80&whse=BC&topnav=
    Check the above link. They have a Denon AVR (3806 & 2807) and price is very competitive plus this receiver has HDMI input/output.
  • EricSS
    EricSS Posts: 5
    Well I was thinking of going with the 987. Why you ask?
    Check this out
    Seems to be exactly the same as the 2807, and I can get the 987 for $550, brand new.
    If that would be enough of a reciver to run as a preamp, then I could spend more on a better amp. :)
  • cfrizz
    By all means, GET IT!!!
