What kind of cable for RTi-10 speaker ?
allen325
Hello guys :
The first time post and first time use polk system. The other one my english is bad so......forgive me..:p
Q1. Have anyone suggestion speaker cable for RTi-10 (Singal-wire or Bi-Wire)?
Q2. As Q1. what kind of singal cable for DVD to AMP connect ?
Thank you very much for help me to solve this problem and very happy join this web . thanks a lot.:p
Post edited by allen325 on
what gear are you working withYamaha RX-V2600
Adcom GFA555 x 2
Yamaha CD685 cd changer
Yamaha Dvd c950 dvd changer
Polk RTi12 mains
Polk CSi3 center
Polk psw303
Polk RTi6 (surround and surround back)
Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
WindyWillys cooling fan (works great)
Mitsubishi 52in big screen
blue jeans cables
AR interconnects -
Welcome AllenThe Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable -
ronnie wrote:what gear are you working with
P.S Accept speaker cable price under US$:150 .
TKS!! -
audioquest, blue jean, and signal cable are favorites among this forum. Good quality 10-12 awg Monster Cable or something similar will do you right for speaker wire. I made my own since I had the time to do it and terminated them all with banana plugs.Shoot the jumper.....................BALLIN.............!!!!!
Sherardp wrote:audioquest, blue jean, and signal cable are favorites among this forum. Good quality 10-12 awg Monster Cable or something similar will do you right for speaker wire. I made my own since I had the time to do it and terminated them all with banana plugs.
could you tell me about detail type or number of monster cable for RTi-10 & PSW-10 subwoofer , TKS!!
Forget the Monster cable. Get some Blue Jeans. They have some nice 10 or 12 gauge wire. You can order to your desired length, use bare ended or they can put on spades or banana plugs. Look here:
http://bluejeanscable.com/store/speaker/index.htmCarl -
Monster cable tends to be over-priced, whereas Blue Jeans you get more for your money.
schwarcw wrote:Forget the Monster cable. Get some Blue Jeans. They have some nice 10 or 12 gauge wire. You can order to your desired length, use bare ended or they can put on spades or banana plugs. Look here:
Thanks for your suggestion , but I can't get this cable(freight) , because I'm in Taiwan not in US so..... Have any other type suggestion ?? TKS!!:( -
I used monster for that same reason, hard to get it shipped out to JapanShoot the jumper.....................BALLIN.............!!!!!
Signal Cable Will ship worldwide. IMHO you will get a much better cable for your money.
i will definitely look into them alsoShoot the jumper.....................BALLIN.............!!!!!
