rt1000 speaker hookup question
charlesw
charlesw Posts: 1
I have the RT1000p speakers. Mine are about 7 yrs. old (in case that matters). To hookup the speakers previously, I had been stripping the wire and inserting it into the hole in the hex nut, which was then tightened. Can I use bannna plugs? If so, where do I insert them? Is there another way to connect the wire w/o having to strip it?
Thank you for any assistance!
c
Post edited by charlesw on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited September 2006
    Yes, you can use banana plugs, you insert them into the tops of the binding posts, you may have to remove the small plastic circle on the top of the post, you need to have the binding straps in place or a small length of speaker wire.
    Any wire will have to stripped unless you purchase it with the terminations already completed.
    RT1
