Opinions sought: Opera-consonance valve monoblocs for my 1.2 TL's
c0redumpt
c0redumpt Posts: 35
edited September 2006 in Vintage Speakers
Gday polksters,
I've been looking at upgrading my 2ch power/pre for my 1.2 TL's for a while, and have come across some opera consonance valve gear...
Im looking at the cyber 222 valve preamp: http://www.opera-consonance.com/products/cyber222.htm
and a pair of cyber 800 monoblocks:
http://www.opera-consonance.com/products/cyber800.htm
I'm a newbie when it comes to valve gear and being in australia its rare to see quality valve gear for sale locally. Im just wondering what ppls opinions might be, ie will it have enough power for the 1.2's whether there might be issues around the common-ground requirements?
Any advice will be appreciated, as would want to ensure they would fit the bill before demoing them
cheers
Post edited by c0redumpt on
    F1nut Posts: 50,729
    I don't know anything about those pieces, but 78 wpc of tube power will work as long as you don't want concert levels. You will have to use the AI-1 cable or find out if you strap the negative outputs together.
  • ND13
    ND13 Posts: 7,601
    From everything I've read and heard about Consonance gear, you should be pleased. Supposed to be real nice stuff.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • madmax
    madmax Posts: 12,434
    Tubes work well with the big boy SDA's at reasonable volumes. As was said above, check out the common ground issue.
    madmax
    Vinyl, the final frontier...
  • c0redumpt
    c0redumpt Posts: 35
    Cheers for the replies Gents, I've talked to the importer here and the owner without any luck re: the common grounding ...
    Have now emailed consonance directly, hopefully they get back to me with some good news :)
    Read abit more about them, cant believe how heavy the monoblocs are... coming in at aroudn 30kgs each I might have to look at a more sturday rack/wall unit if I get them :D
