Monster THX Ultra for $9.97
Gaara
Don't mean to one up Toxis, but I saw these while shopping yesterday for some bananas I needed. Radio Shack has a bunch of the Monster THX Ultra stuff on sale, like a S video for $17, or optical for $17, but these are definitly a better deal then those. Hell I use some of these for my primary system, not to shabby for less then $10.
here
here
Post edited by Gaara on
I have these in the HT, they work and sound good and are thick with tight connections.. definatly worth the 10 bucksMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
What is the difference between these and the i400 MKII cables other than length?
I need some interconnects for my 5.1 input. thanks.
Found some info;
http://www.monstercable.com/THX/productPage.asp?pin=1708
http://www.monstercable.com/productPage.asp?pin=133
Ordered some. Heckuvva deal
Thanks for the heads up Gaara.
