Dual 1218 turntable - how do you get the platter off?
dragon1952
Anybody know? It doesn't just slide off. There must be some kind of release or something.
Thanks.
Thanks.
Post edited by dragon1952 on
It's probably a snap ring on the spindle. Here's the manual for a 1219.
http://www.vinylengine.com/library_model.php?make=Dual&selected_model=1219
http://www.dual-reference.com/tables/1218.htm>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Thank you very much dude! I guess I don't have to take the platter off after all....I was looking for a belt
I wouldv'e sworn this was a belt drive. It's actually an idler wheel drive. What a dunce
2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
You should remove the platter for regular maintenance, i.e., clean and oil the spindle well, clean the ilder and inner platter rim, etc.More later,
Tour...
Vox Copuli
dragon1952 wrote:....I was looking for a belt
No, you're an optimist.
