Cal Tjader "Hurrican"
I-SIG
I-SIG Posts: 2,243
edited October 2006 in Music & Movies
I did a search and Cal Tjader has only been mentioned a couple of times on here so I thought I would give a quick shout-out.
A friend let me borrow a Cal Tjader CD, Hurrican. First thing to note is that it is on a LaserLight "Crystal Clear" audiophile disc.
The clarity and separation really jumped out at me as soon as I hit play. "Wow!" is all I can say! Wide soundstage, great distinction among the instruments even when eveything is playing.
If you want some supe rclear jazz with a latin twist to, I can't recommend it enough.
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
  • DAGLJAM6
    DAGLJAM6 Posts: 635
    edited September 2006
    Find and purchase- Cal Tjader-"La Onda Va Bien" on SACD and be prepared for the same reaction....
  • I-SIG
    I-SIG Posts: 2,243
    edited October 2006
    Thanks for the tip!
    Wes
