amp selection
surfntomm
ok i have finally decided what i want to do and tell me if you think its a good choice. i have a denon avr 2106 rti70s csi5 and rti6 for my rears. i was thinking that when i watch dvds it can already go pretty loud and sound just fine so i dont think i need a 5 channel amp but i was thinking of getting a decent 2 channel amp to get much better sound when listening to music. does that sound like a good idea? would having just a 2 channel amp make my ht sound weird since my fronts would be getting more juice? if not then what kinda amp would you recommend. from what ive been reading and what not, i think id like a parasound amp since they are geared more towards music? or will that be over kill since the rti 70's are not elite speakers when compared to other models and what not. any input on what you think is resonable and worthwhile let me know. thanks for your input in advance
Post edited by surfntomm on
surfntomm wrote:ok i have finally decided what i want to do and tell me if you think its a good choice. i have a denon avr 2106 rti70s csi5 and rti6 for my rears. i was thinking that when i watch dvds it can already go pretty loud and sound just fine so i dont think i need a 5 channel amp but i was thinking of getting a decent 2 channel amp to get much better sound when listening to music. does that sound like a good idea? would having just a 2 channel amp make my ht sound weird since my fronts would be getting more juice? if not then what kinda amp would you recommend. from what ive been reading and what not, i think id like a parasound amp since they are geared more towards music? or will that be over kill since the rti 70's are not elite speakers when compared to other models and what not. any input on what you think is resonable and worthwhile let me know. thanks for your input in advance
Hi Surf,
Many people add just a 2 channel amp to their systems for better music. The parasound will make your speakers sound a lot better than the receiver you have now. Whether it is overkill with the rti 70's, only you can make that decision. If you find a great deal on the Para, it can always be used later if you do upgrade.
HT use will be fine with the amp. You can always adjust the gains for optimal playback. Just 1 caution though. If you do go down this upgrade path, it will never end. Next you will want to add a better 2 channel preamp, speakers, wires, source, etc....I started with a receiver, now I have a whole rack of crap... Turn back now while you still have a chance. It is too late for me.
Venom -
venomclan wrote:Hi Surf,
If you do go down this upgrade path, it will never end. Next you will want to add a better 2 channel preamp, speakers, wires, source, etc....IVenom
any one have thoughts on the parasound hca-1500A or the hca-2200 II for 2 channel listening? -
You will love either one of them. I have the 1500A & it rocks!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Hi surf,
Parasound HCA-1500A is an awesome amp for HT and music. You will definitely like the sound of Parasound. This amp is on warmer side and will tame your tweeters on your Rti70s. Also, separate amp will free up more power from your Denon for centre and surround. 1500A has a nice and tight bass. At 205 WPC the 70s will rock for sure. Owerkill??? not at all, just nice clean sound.
GatorTheatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre -
i'm using one Outlaw M2200 Monoblock per front speaker and mine sounds great on the HT and Music side of things. Im now looking into either another M2200 or a 3 channel amp.Shoot the jumper.....................BALLIN.............!!!!!
Surfntomm, this is about the comment you made about the RTi70's not being elite speakers. I recently added a Outlaw 7700 (200x7) amplifier to my 70's and after listening to them for the first time I thought I had changed my entire setup. The 70's opened up like they were totally different speakers, the highs are crystal clear, and the bass is accurately tight and very responsive. You will not be disappointed if you add an amp to those 70's, I promise.Money Talks, Mine says Goodbye Rob!!!!
Good point on how changing the amp/reciever can transform speaker performance. All things being equal, more power will generally improve speaker parformance. Power does not make a speaker play louder so much as it makes the speaker play cleaner (assuming there are no issues with impeadance matching).
