Whats causing low hum...
Grimster74
Grimster74 Posts: 2,577
edited September 2006 in Electronics
As many of you know in my dedicated room I have 2 dedicated 20 amp receptables (sp), one for equipment and the other for the SVS. I noticed since I added the Outlaw 990/7700 combo, there is a real soft hum coming threw the speakers, the only time you can really hear it is when you place your hear right next to the speakers but the hum is there where it wasn't there when I had just the Denon 3805 connected. I'm using the balanced connections which is supposed to get rid of the hum but if I hook up the analog connections to the amplifier you can really hear the hum from like 5 feet away. Is there anything I can add to the system to get rid of this hum or ground loop problem? Thanks.
Post edited by Grimster74 on
  • danger boy
    danger boy Posts: 15,722
    sounds like a call to Outlaw tech support is in order.. for some reason their amps seem to be causing a few "minor" problems when connected to their own 990 pre amp. and it's not the pre amp.. since I have the 990 pre amp, but not any of their amps. so go figure. I don't have any of the issues others have mentioned with their amps.
    PolkFest 2012, who's going>?
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Grimster74 wrote:
    ...the only time you can really hear it is when you place your ear right next to the speakers...
    Quit putting your ear next to the speakers, sit down, and enjoy!
    The only way to troubleshoot a ground loop, is disconnect EVERYTHING, and start over, adding 1 component at a time to isolate the issue(s).
  • wingnut4772
    wingnut4772 Posts: 7,519
    Hey Grim. I had the same problem when hooking up my gear again. I did some pretty thorough wire management - separating the interconnects from speaker wire and electric cables - and that cleaned it up pretty well.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • tledoux
    tledoux Posts: 17
    I had the same problem with my 7500 connected to my Yammie, but I was
    using the un-balanced inputs. So I got the VRD-1FF Model ISO-MAX Ground
    Loop Isolator (also available from the Polk Store), and there is not even a
    minor hum anymore at all.
    http://shop.polkaudio.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=13352&storeId=12352&productId=107359&langId=-1
    Fronts: Polk RTi10
    Surrounds: Polk TC615i
    Center: Polk CSi5
    Sub: Velodyne DLS-3750R
    Receiver: Yamaha RX-V1600
    Amplifier: Outlaw 7500
    DVD/CD: Sony DVP-CX995V
    HDTV: Sony KP-51HW40
    RC: Philips TSU-6000
  • adam2434
    adam2434 Posts: 995
    I started a thread about this cable ground loop isolator last week: http://www.cencom94.com/gpage.html8.html For some reason, the link isn't working, but the model is the Holland CISP and it is about $12 shipped.
    Here's the manufacturer's page; look under filters/diplexers: http://www.hollandelectronics.com/catalog.html
    It removed the hum I was getting and is compatible with my analog, digital HD, and high speed internet cable service.
    If you have cable hooked-up to your system, try disconnecting it and see if the hum goes away. If so, this isolator is a good thing to try.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • amulford
    amulford Posts: 5,020
    What Russ said. Sounds to me there is a loop issue, but where I can't say.
