Which specs are better?
univera
univera Posts: 848
edited September 2006 in Electronics
I am doing some research on two similar amps, and wondered what technical gurus thought was the more desireable amp:
First is the NAD 2200, 100 WPC @ 8 ohms, <120 Damping factor, +-6 DB headroom. This isn't the PE model, but I belive the power ratings are the same for that one. (The PE may have more more headroom, but I'm not certain.)
Second is NAD 2200A, 150 WPC @ 8 ohms, <100 Damping factor, +- 4 DB headroom.
Both have equal distortion rating and seem to have the same dynamic power ratings.
Are they tossups? What is more important, 50 extra WPC while giving up 2 db headroom or 50 WPC less but 2 extra DB headroom? I don't understand damping, but everything else I am clear on. Curious what the veterans think and what you would choose if you were going with one versus the other.
2200A:
Continuous output power into 8 ohms 150W (17dBW) Rated distortion (THD 20Hz - 20kHz) 0.03%
Clipping power (maximum continuous power per channel) 200W
IHF Dynamic headroom at 8ohms +7dB IHF dynamic power (maximum short term power per channel)
8 ohms 400W (26dBW), 4 ohms 600W (28dBW), 2 ohms 800W (29dBW)
Damping factor (ref. 8ohms, 50Hz) >120 Input impedance 20kohms / 820pF
Input sensitivity (for rated power into 8ohms) 1.2V
Frequency response 3Hz - 100kHz / +0, -3dBdB Signal/noise ratio ref. 1W 100dB
ref. rated power >117dB THD (20Hz - 20kHz) <0.03%
2200 specs:
http://207.228.230.231/info/NAD_2200.pdf
UNIVERA
Historic Charleston SC
2 Channel:
SDA-SRS's RDO tweets
Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
Anthem Pre 2L w/E.harmonix platinum matched 6H23's
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
DVD: Toshiba 3109 dual tray
Subs: Velodyne and M&K
T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
Conditioner: Panamax M5100EX
Master Bedroom Sony 40KDL-XBR3
"I love it when a plan comes together." Hannibal Smith, The A-Team
Post edited by univera on
  • Sherardp
    Sherardp Posts: 8,038
    I would go for the 2200a more power to play with, whats the price difference between the two?
  • univera
    univera Posts: 848
    It's not so much a price difference as a learning experience as to what carries more weight. I have a 2200 and a 2200A is available as well. If my recevier using the 2200a doesn't sell, I was considering keeping it and biamping another rig. That would be a super SS setup. The "A" models don't come around often while the 2200's are plentiful.
    UNIVERA
    2 Channel:
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Funny that NAD did this since, 100 watts with 6 db headroom = 150 watts with 4 db headroom. Basically the same amp output measured differently.
    I would hope that the newer version wasn't simply a rerated version. Sounds like something Sony would be guilty of huh?:eek:
  • Sherardp
    Definitely
  • univera
    univera Posts: 848
    Dennis, you seem to feel the numbers are equal. However; the "A" model does have what I believe are left and right gain controls on front. The 2200 does not have that feature, so they aren't exactly the same. The NAD site doesn't give any info on the "A" model other than listing it as the amp section of the 7600 receiver. It was designed as part of the monitor series and was the top of the line amp offered during that time.
    UNIVERA
    2 Channel:
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
  • jdhdiggs
    jdhdiggs Posts: 4,305
    Get the A, the dynamic power is virtually identical, the sustained power is a bit more important. In the end, I really like the gain controls. It gives you some freedom in the future.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
    mhardy6647 Posts: 34,983
    Buy on the basis of sound, not specs. The spec wars ended about 25 years ago.
  • univera
    univera Posts: 848
    MRH, agreed, but one can't always listen ahead of time...and, NAD is as honest as they come about ratings, so this is a fair analysis, IMO. Plus, I was essentially trying to determine if 2db headroom difference was really any difference of if 4db was plenty as I suspected. Best regards.
    UNIVERA
    2 Channel:
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
