anybody have/use a amp stand ?
faster100
Im getting my rotel 2 channel amp tomorrow to power the lsi15's and ran out of room on my audio rack.. I think beings i have a wall mount tv that an amp stand under it and in between the mains would look and work great!! any idea's on reasonable brands, anyone have one to sell? stuff like that.. suggestions
I called my local granite shop and they will make a 19" x 22" (stole the dimensions from a commercially made one) round over the edge and polish it and drill 4 holes in the bottom for spikes/feet for around $100 bucks
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
Salamander makes a nice one. It can probably be had online for about $150. Take a look at audio advisor. Sometimes they have them on sale.
BTW, $100 for the granite really isn't too bad. At about $50 sq/ft, it isn't a cheap item.Tschüss
Zach -
Definitely get the granite. For $100, you can't beat it. Just buy a set of nice spikes for it and you're good to go.
A less expensive alternative is to get a 2" thick cutting board and drill your own holes. Check out www.timbernation.com for the best prices. He sells stuff on the 'gon, too.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I'd get the granite.
Granite.
If you are having one made you might as well measure the amp and make it fit.
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
I-SIG wrote:You mean something like this...
Wes
No, just a stand for the amp... The 1080 rotel im getting, I have an audio rack for the rest of the stuff.. but that is a cool rack and we went back and forth if we wanted a stand for under the plasma or the one off to one side.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
I use this stand, since it matches my EFAV-3 Euro II.
http://www.audioadvisor.com/store/productdetail.asp?sku=SANEFAB2
I would go with granite though if had the $100 pricing in my area.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I use 18" concrete patio blocks, painted black and silicone sealed to a plywood base that has spiked feet from Parts Express mounted. Works great. I have my Outlaw M200's for my HT on these. I also mounted wood strips around the outside, also painted black, so all you see is about 1/4" of the concrete patio block sticking up. Works great, and cheap!DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
after all this, i might be able to fit it on the rack if i put my dvd on the pre.. I still like the granite idea and its not out of the question yet.. Thanks for all the helpMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
A nice piece of MDF covered with vinyl and spikes on the bottom will do everything you need very cheaply.
madmax wrote:Someone needs a cable specialist... :eek:
madmax
I'm not quite ready to start drilling holes in my sheetrock for the TV cables. Plus, I'm trying to spread the load around to different outlets. Onc eI install my new 20A outlets, hopefully this winter sometime, things will improve greatly.
WesLink: http://polkarmy.com/forums
You could just tie wrap the bunch together, pull them to the side and let them hang down next to the speaker. Who am I to talk anyway, mine are a mess...
Just don't run the power cable in the wall. If you are running new lines to the room, take a look at the Panamax MIW(mount in wall) surge protection system. It uses romex in the wall and a recessed outlet behind the television, and an the other end at the base of the wall.Tschüss
Zach
