Just purchased this set...
Grimster74
Grimster74 Posts: 2,576
edited September 2006 in Speakers
Just today I purchased this satellite/sub http://www.crutchfield.com/S-hnHskcSSILU/cgi-bin/ProdView.asp?g=12700&I=700RM6005B combo from Crutchfield for my wifes setup upstairs which will be replacing a set of KLH's which only consisted of the L, C, R and a passive KLH sub. My question is this, I noticed on the PSW10 subwoofer the only 'Line In' is left and right and it is unfiltered. I prefer not to use the speaker level inputs just to keep down on the clutter of speaker cables so how exactly do I hook this setup up using the LFE out of the 3805. Do I just hook all the speakers up to the receiver then run a subwoofer cable out of the 3805 to a Y-adapter into the left and right input of the sub, or do I just run to either the left of right into the sub with a single subwoofer cable. Any help would be greatly appreciated.
Post edited by Grimster74 on
  • tryrrthg
    tryrrthg Posts: 1,896
    Unless the 3805 has an adjustable crossover (that goes up to 150hz or so) you'll want to use the speaker level connections or else you'll have a gap in the frequency response between the sat's and the sub.
  • Grimster74
    The adjsutable crossover frequencies of the 3805 are as follows: 40, 60, 80, 100, 120, 150, 200, and 250Hz.
  • amulford
    amulford Posts: 5,020
    your good to go
  • Grimster74
    So, maybe I missed something but do I a) use the Y-adapter w/subwoofer cable, b) use a single subwoofer cable or do I c) use the speaker level inputs to get the best performance out of these speakers.
  • dale 442
    dale 442 Posts: 98
    I have this set as well. With an upgrade up front.
    Try both ways of hooking up the sub. Use a Y- adaptor. They both work, but you may prefer one hookup over the other.
    Experiment and have some fun with it!!
    Dale
    Polk SDA 2B's
    Carver TFM-45
    Sony X33ES CD-direct to Carver
    Samsung 4051D 40" LCD
    Samsung DVD
    Paradigm PS-1000
    Denon 1507 A/V receiver, video only
    Rti4's Front and Rear, video only
    CSI3 center, video only :rolleyes:
  • tryrrthg
    You can do any of them, but option a or b will work, just be sure to set the crossover on your receiver slightly above where the sat's roll off and turn the crossover on the sub all the way up.
  • Grimster74
    Thanks tryrrthg, that was my next question, what to set the crossover on the receiver and the subwoofer at?
  • tryrrthg
    I would try 150 and or 200 on your receiver. The freq. response of the sats is down to 150hz.
    Turn the subs crossover as high as it will go.
  • Grimster74
    COOL, thanks a million
