sub box plans
![scootersel](https://forum.polkaudio.com/applications/dashboard/design/images/banned.png)
scootersel
Kim, I have a few questions about sub box plans.
I came across some plans I copied off of your website on 7-29-2000.
They almost look like a box plan of the month web page.
There are different plans for single db 12s,2 db 10s,single8s,4 EX 12s, 2 EX10s.Possibly more. All in different bandpass boxes.
They all come with specs so that you know what size cutouts you need.
They have computer generated pictures to give you an idea of what it is supposed to look like.
I guess what my main question is can I use a 12" DX instead of a 12" DB?
Also on the plan it shows the sub mounted to a 12.5" square baffle is that right?That does not seem like enough to support the sub and it does not give a lot of room to screw the panels together.
Post edited by scootersel on
Hi Kim, those bandbass drawings are way more detailed than the dual sr124 vented drawings. is vent location critical at all in the dual sr124 design?
