Velodyne sms1
dholmes
I have the Velodyne sms1 for about a month now, it has helped the bass in my ht alot, I just did the auto eq so far. Does the preset fuction 1-6 work if you just use auto set up? When I turn on the Velodyne it goes to preset 4, volume 10. I like the volume on about 15, but was wondering if it matters which preset you have it on when using the auto set-up. thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
By the auto set up do you mean the Self EQ?...in the 321 screen? Either way they SMS settings 1-6 will give you different results. I like either setting 4 or 2. Listen to both and see which you like best. If you did mean the Self Eq (where the SMS just calibrates the sub only) then you are really missing out by not going into the manual EQ (12345 menu) and fine tuning the curve. It makes a big diiference and integrates it with your speakers.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Thanks, I meant the self eq. I guess I need to go through the manual eq then, Ill need to hook-up the eq to a input on my pre-pro L&R. The self eq took out alot of boom! thanks againMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
dholmes wrote:Thanks, I meant the self eq. I guess I need to go through the manual eq then, Ill need to hook-up the eq to a input on my pre-pro L&R. The self eq took out alot of boom! thanks again
Yes it's really a further improvement and well worth it. Have fun!:)Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
