Rainy wkend ahead / need sub hookup advice
pearsall001
Since this weekend looks like a wash out I want to experiment with my SVS sub. I only have it hooked up doing HT duty. I want to try it in 2 channel mode. How do I hook it up? My receiver is a NAD T773 using sub-out. My 2 channel system is a CJ tube preamp, AVA amp, Consonance CD120 player, & AAD 2001 monitors. Can I do both together or do I need to keep the hookups separate? I never considered the sub for 2 channel but this is a perfect weekend to see if I like it. Thanks
Post edited by pearsall001 on
Depends how close your receiver and pre-amp are, I would get a Y splitter. T hat way your sub will be getting a signal no mattter which receiver you use.
