Rear port in speakers??
tecmo04
tecmo04 Posts: 421
edited September 2006 in Speakers
I am concidering purchasing a pair of monitor 40's. My question is these speakers have their air port in the rear. Since i would be using them as rear speakers they are wall mounted. This means that the backs of them would be flush against the wall in essence blocking the port...
Is this ok for the speaker? What other options are there??? Any advise.
Post edited by tecmo04 on
  • Skynut
    Skynut Posts: 2,967
    Space them off the wall an inch or two.
    Maybe put rubber feet on the back of them before hanging them.
    That should help.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Early B.
    Early B. Posts: 7,900
    Find another pair of speakers.
    "God grooves with tubes."
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Just stuff the port with a foam plug, and you'll be fine.
    VR3 Posts: 28,782
    Id get different speakers...
    Plugging the port will remove all traces of low end that was there before...
  • Ern Dog
    Ern Dog Posts: 2,237
    I've got my monitor 30's against the wall and don't have a problem with this. They came with rubber feet on the back which creates a 1 inch space between the speaker and the wall. I don't know if the 40's have these feet, but if they don't it would be easy to put some on.
  • RuSsMaN
    Who cares, he's using them for surrounds. Certainly better than the port chuffing against the wall.
    VR3 Posts: 28,782
    I like having bass in my surrounds - but I'm weird...
  • mrbigbluelight
    mrbigbluelight Posts: 9,858
    The Monitor 30's are only 8 3/8 inches deep.
    The Monitor 40's are quite a bit deeper at 12" deep.
    Move them too far from the wall, and they'll be sticking out like Grandma's arm signaling for a left turn.
    Those 30's also have a keyhole slot, made for wall mounting.
    The 40's don't.
    I don't know what your room setup is, but stands may be an option.
    The 40's mounted out from the wall above a couch might make some folks a little paranoid.
    If you get to the point of thinking about plugging the bass port, I think you ought to just drop down to the ol' cheapo R15's with the front-firing port.
    We are talking surrounds here, so the main emphasis should be on the fronts and center.
    And the R15's, while no Amazings, are ....well, kind of amazing for the price/size.
    Used 4 R15's for side and rear surrounds at the daughter and S-I-L's, and for their basement setup, it sounds pretty nice for HT.
    You do have a sub, I assume.
