Winter Tire sizes
Willow
Willow Posts: 11,310
edited April 2024 in Clubhouse Archives
Yes it may be atadd premature, but we are looking at winter tires again. Does anyone know what the smallest size we can go to? our tires are 215/65/16.
thanks
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited August 2006
    What vehicle are these going on ?
  • faster100
    faster100 Posts: 6,124
    edited August 2006
    you live in canada and don't know what snow tire to use? :D:)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • Willow
    edited August 2006
    Nissan Xtrail Se
  • Willow
    edited August 2006
    I know which ones to buy I want to save money by downsizing a bit and not sure what i can go down to.
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited August 2006
    Do you want to keep the odometer accurate? You could vary the width and ratio and see if you can get cheaper tires. The only thing fixed in your setup is the wheels. I would guess you could go with 205/XX R16 where the XX could be anything from 35-75.
    Personally, you should only be saving $40 at most so why not keep them the correct size?
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • faster100
    edited August 2006
    what's an xtrail?
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Willow
    edited August 2006
    faster100 wrote:
    what's an xtrail?
    they are not yet avail in the US they have been in Canada for a couples yrs and in europe for even longer.
    http://www.nissan.ca/en/vehicles/xtrail/index.html
  • Willow
    edited August 2006
    Wouldn't that be keep the speedometre correct ?
    On our matrix we went down a couple sizes for our winters. I don't remember what the rule of thumb is.
  • jdhdiggs
    edited August 2006
    No rule of thumbs needed: http://www.tiredepot.com/calc.html
    First number is the tire width, second is the ratio of sidewall to width, the third is your wheel diameter. If your standard tire is 215, it might be hard to go below 205. You might try 195/70 R16 or 205/70 R16. Both of these won't result in too much odometer descrepencies.
  • Willow
    edited August 2006
    thanks for the link
