What affects sound more- amp or reciever?
Ace944gs
Ace944gs Posts: 110
edited September 2006 in Electronics
Hey all-
IYO, what makes the most difference for sound (keeping all other components the same)- an amp or a reciever?
Specifically, I'm working really slowly on building my system, and I currently have an HK 635, which I love. I'm moving to a bigger place in a few weeks, and can't wait to use the money I saved up for some LSi9s for my 2ch. setup. What can I expect when I add an amp, in terms of sound quality? I know my HK is probably underpowered for the LSis, but I love the sound of the HK, and wonder what exactly I should look for for my amp selection. Will buying one particular brand of amp affect the sound differently than another? Thanks!
Post edited by Ace944gs on
  • AndyGwis
    AndyGwis Posts: 3,655
    edited August 2006
    Hi Ace,
    I have the 635 and moved to power amps to help in 2-channel. They do make a big difference, and I wouldn't hesitate to tell you to try out some nice used amps on your LSi9's.
    I like the warm sound of the B&K st-202 I purchased and it would mate very well with your 9's in 2-channel. 200wpc would be good for those bookshelfs, although you may need more if you had lsi15, which are more power-hungry due to powering woofers.
    Start looking around audiogon for some stereo amps. Where are you located? You can even query for items near you area to save on shipping.
    Also, what's your budget for an amp, and have you also considered getting a pre? I have a B&K St-202 and Pro-10MC and love them!
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Ace944gs
    Ace944gs Posts: 110
    edited August 2006
    I'm located in Tampa, FL. I havn't really considered a pre, mostly b/c of budget and the fact that I recently bought the 635 and love it :). Unfortunatly I will have to wait a few months after I get the LSi9s to get the amp, so I'm not entirely sure what the exact budget will be, but I'm hoping for sub $500 (is that reasonable?).
    I havn't begun doing that much research for the amp, but your response is encouraging! I've heard (personally and from others) only great things from Hks, LSis, and can't imagine adding a good amp will hurt the sound.
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2006
    Hi Ace. Since you like your HK by all means keep it. Just get a 200wpc or more amp to hook up to it & be amazed at the difference.
    You will have greater clarity, better musical separation, better bass, as well as being able to really crank it!
    Keep a look out @ Audiogon for Parasound, Rotel, Sunfire, Outlaw.
  • AndyGwis
    edited August 2006
    Frizzy is right, no need to ditch the 635. It's a great pre, but I was under the impression the 635 was for your HT setup and you were building an entirely new 2-channel setup with the 9's. My mistake if that's not the case.
    I have used my 635 as a pre for quite a bit, no problems there, and it's bass management would easily allow for a sub with those 9's, if you so desire.
    $500 on the used market will go a long way. I'm sure you could get something in the $350 / $400 range with the way prices are right now and be totally happy. If you go up to $500, the possibilities are really quite strong for an almost like-new amp from any good company mentioned above.
  • faster100
    faster100 Posts: 6,124
    edited August 2006
    The answer is all of the above.. I had a denon receiver as a pre and a outlaw amp, sounded nice but i sold the denon and got a stand alone pre-amp for ht.. sounded excellent, night and day almost... now i returned the outlaw amp and for rotel.. similiar wattage and it to sounds different.. you have to, if you have the means and patience to try different amps to see what sound you like or take advice from people who know said amp and brand.. the HK will do nice for a pre-amp with an external amp of your choosing. a better pre will only improve on it, amps........ thier are many, name the wattage, style you like and the sky's the limit... for a 5 channel or more $500 wont cut it... if your talking 2 channel they start at 150 for decents ones and on up..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
    F1nut Posts: 51,783
    edited August 2006
    That's a bit of a stretch, don't you think. It may be OK or good, but great it ain't.
  • Ace944gs
    Ace944gs Posts: 110
    edited August 2006
    Thanks for the feedback! right now the HK will have to remain as the pre for the 2ch. as well. I honestly rarely watch media needing surround sound, and would say 80-90% is good old stereo music. Thats great news to hear I can get a 2ch. amp in the under $500.00 range, used.
    I have to admit as well...the LSi9s will be sub-less for as long as I'm in school. Still, every time I've listened to them w/o sub I'm totally fine w/ the sound...still like them :)
    faster100- I guess that is what I'm looking for- advice from people who have used HK & LSis and what their recommendations for amps would be... I havn't found an accomodating store in the area (tweeter is all I've found) for demos...so the sage advice from polk forum members is what I'm going to have to base my decision on!
  • ruffjustice
    ruffjustice Posts: 61
    edited August 2006
    heat affects quality of sound for tube amps due to the change in bias resistances when tubes become overly heated .. i should know i used to run 300-400 watts om am in 27 mhz. band know as c.b. ; transisitor amps alway's sounded crispy when run at full pwr. so to would run them at 1/4 power to achieve a swing let say dead key 25 watts - 125 peak ! and the am audio would be much louder n clearer for trans. amps, but nothing beats tube amp for that nautral sounding audio ! :eek:
    F1nut Posts: 51,783
    edited August 2006
    Ok, who has the decoder ring???
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited August 2006
    and that was edited.............
  • faster100
    edited August 2006
    and what does cb amps have to do with this?
    I just happen to be an old (young) cb'er and know what's what on that subject.. however in home audio we can't set or adjust our power output besides with the volume knob.....
    in cb radio, the driver.. ie: the cb or modulator that drives the bigger amp is what determines the final output.. and is also driven by a persons voice, ie: modulation.. if the driver puts out more the amp puts out more.. and if the driver output is lowered it works in reverse..
    so you see, its no where related to home audio :D
    derail over :)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • AndyGwis
    edited August 2006
    Fine, the 635 is an "able" pre-amp. If you're on a budget 2 channel, get the amp first; the 635 will get you by just fine for the time being.
  • ruffjustice
    nothing .. just a comparisom in audio quality .. doe's everything i post has to be pick .. like a turkey after thanksgiving day ,lighting up and you will live longer...
  • ruffjustice
    nothing.. for comparison relax have a martini or 2..3 dude
  • cfrizz
    No offense Ruff, but you took this so far off into...whatever field that you confused the blazes out of everybody!
    No one asked for comparisons between tube amps & cb amps?:confused: So no one could figure out what you were talking about!:eek: :D
    But I guess as long as you know what you are talking about the rest of us can just stumble around in the dark totally confused!:p ;):D
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    I fail to see how "lighting up" will help me live longer.:confused:
    Wouldn't that just lead to my early demise, or do I have it all wrong:p
  • PolkThug
    PolkThug Posts: 7,532
    It translates to : "All your base are belong to us."
  • jdhdiggs
    jdhdiggs Posts: 4,305
    HK + LSi = Dark and Veiled. HK amps and LSi's really don't mate well together. My 7's didn't do well with the 5800 and others have reported similar issues. I would recommend a change to an amp ASAP.
    If you are serious about the ~$500 for an amp, there are some GREAT amps from brands no one has listed. $350 is about the primo entry point but $500 is were stuff starts getting interesting.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
