Broken Binding Post
audiobliss
audiobliss Posts: 12,518
edited August 2006 in Electronics
Help! I opened up my amps to tighten the binding posts, and I ended up breaking one of them off! Appearantly the outside portion of the binding post goes through the amp 'wall' via a 'screw' (that I suppose is actually just one piece with the outside unit), and then a nut tightens down from the inside to secure the binding post. Well, I was tightening 'em all down...in fact, I had already tightened down my other three amps...when I noticed that it was really loose on this one. FYI, this is an AV-20. I then noticed that the back of the unit is dented in, as in shipping damage or what not, so I figured something got knocked loose. Anyhoo, I'm tightening and tightening...'cause it's REALLY loose...I mean, I can move the binding post in and out a good 1/4". But there's a good bit of resistance, which I wouldn't expect...and then pop. I sheared the 'screw' part. It's now in two pieces.
I'm attaching pics of it all, including the rear where the damage is.
Now, what in the world do I do at this juncture? I just thought I was lost when it came to understanding audio and buying and setting up stuff...now I'm really lost.
Help!
Michael
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2006
    This is a perfect time for a binder upgrade. You need chassis mounted binders...and I would suggest Vampire Wire.
    Break out the soldering iron and get busy.
  • audiobliss
    edited August 2006
    That seems like a great idea. Sid just suggested it, too. What if I can't solder? During the summer working for a HVAC repair place I actually brazed twice. But that (at least what I did) required NO finesse.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited August 2006
    Ok, I'm actually not so upset this happened, now. I'm *almost* excited about upgrading the binding posts.
    Also, I now have just the Wave 8's hooked up, so it's nice to go back to those so I can get a better idea of the difference between them and biamping, and I now am bi-wiring.
    So, what're some good options for binding posts? I want something nice. And since I don't imagine binding posts can cost that much, I'm guessing I can get some nice ones. What do y'all like, and where do you like to get them?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited August 2006
    Parts express has 68 pages of posts when using "binding post" as a search keyword.
    You sure don't have to buy from them, but they offer lot of brands and options at all $$$ levels.
  • faster100
    faster100 Posts: 6,124
    edited August 2006
    you wont be so excited when you see what "good" binding posts cost :D
    it will be worth it though, beings they are broken now anyways :)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • schwarcw
    schwarcw Posts: 7,358
    edited August 2006
    I'm with Doro, buy some Vampires. Very reasonably priced and high quality.
    Carl
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited August 2006
    F Vampire, Cardas baby - all day all about (in my best Mantis voice).
    You can handle it, since I sold them to you, if you want to ship them back here, I'll gladly knock it out for you.
    Oh, and RELAX. Tubes are easy.
    Cheers,
    Russ
    F1nut Posts: 51,749
    edited August 2006
    Cardas or WBT if you want the best. However, the other brands will work too and for less money.
