Newbie questions/Ohms
patnuh
patnuh Posts: 4
edited August 2006 in Speakers
I have a starter setup that includes a Polk CSM center and 2 bose for surround. They are both rated @ 4ohms(the Polk compatible w/8). I'm using a Yamaha receiver that can be programed for 6 or 8 ohms. Should I use the setting for 6 or 8 ohms?
Post edited by patnuh on
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited August 2006
    Try it both ways and see what sounds best to you. The 8 ohm setting will probably run a bit cooler on the electronics if you listen at high volume levels.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2006
    I believe the 8 ohm setting will make the receiver hotter not cooler when listening at high volume levels.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
