Onkyo HTR SHORT CIRCUITING
gwsolace
gwsolace Posts: 16
edited August 2006 in Electronics
I am currently using an Onkyo 5.1 receiver, about 3-4 yrs. old. I recently moved and am hooking up my speakers again. The receiver would turn on and then turn off with the standby light flashing. Is that an sign of an short circuit? I tried to wire just my front mains, still did it. Don't know what I did during the move. Any suggestions? How do you tell if an receiver is short circuited? Thanks
Post edited by gwsolace on
  • brettw22
    brettw22 Posts: 7,623
    edited August 2006
    Few questions for you.....
    What type/model of speakers are you using? How many channels are you running? Are you sure that you don't have a wire crossed (neg to pos somewhere in the mix)? What model Onk is it?
  • gwsolace
    gwsolace Posts: 16
    edited August 2006
    it is an ht-r500 with 5 channels to Polk csm, r50, r15s. I thought it might be miswired. So, I just connect the mains and I am sure the pos and neg are right, still. turns on then just turns off. the standby light keeps blinking.
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2006
    Have you tried another electrical outlet?
  • millerman 3732
    millerman 3732 Posts: 1,488
    edited August 2006
    I had an onkyo txsr 600 that went in to protect mode and I had to do a reset of the receiver to get it to come back on
    Just checked out the Onkyo website to reset the receiver you must hold down the video 1 button then press the on stand by/on button. the word CLEAR should appear on the front display and it will enter stand by mode and the receiver should be reset. Idon't know if it will fix it but you might give it a shot.
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
