SDA Question
pal51961
Are all srs 2.3's created equal? Are there different tweeters in some? Thanks.
If you can catch it, I can cook it.
Pioneer Elite vsx72txvi
Pioneer Elite dvd36
Toshiba DR5SC dvd recorder
Moxi HD DVR
Acurus 200X3 (by mondial)
Adcom GFA-545
Monster Line Conditioner
Polk LSI 15
Polk LSI 9
Polk LSI C
Hsu VTF-2 Sub.
Sony SXRD 60 inch.
Pioneer Elite dvd36
Moxi HD DVR
Adcom GFA-545
Polk LSI 15
Polk LSI 9
Polk LSI C
Hsu VTF-2 Sub.
Sony SXRD 60 inch.
Post edited by pal51961 on
No they are not. There is a later model run, named the 2.3tl, i believe. It is a more refined design with different tweeters
Tony's right. The SRS 2.3 used the SL2000 tweeters and the SRS 2.3tl used the SL3000 tweets. I believe they also had different crossovers. The cabinets looked the same but were utilized in a way that was.... shall I say, backasswards of each other.
