Single 8" or 10" sub suggestion
univera
univera Posts: 848
edited August 2006 in Car Audio & Electronics
I would also like to get a small, sealed sub for my trunk that WON'T take up much room in my Prelude. I am thinking one 8" or 10" (10" preferred) sealed sub that can slam. I want super tight, hard bass, so ported stuff is out of the question.
I previously used a JL arrangement with 3 10" subs years ago. I loved the sound, but taking up the entire trunk is not an option these days. I need something that can stay in the back section near the rear deck and that doesn't require a large, heavy enclosure.
UNIVERA
Historic Charleston SC
2 Channel:
SDA-SRS's RDO tweets
Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
Anthem Pre 2L w/E.harmonix platinum matched 6H23's
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
DVD: Toshiba 3109 dual tray
Subs: Velodyne and M&K
T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
Conditioner: Panamax M5100EX
Master Bedroom Sony 40KDL-XBR3
"I love it when a plan comes together." Hannibal Smith, The A-Team
Post edited by univera on
  • MacLeod
    MacLeod Posts: 14,358
    edited August 2006
    MM2104 is for you! Works in a small box and sounds great with average power.
    Thats what Im running in a .58 box and I got mine to fit in a ridiculously small space.
    http://www.polkaudio.com/forums/showthread.php?p=331463#post331463
    VR3 Posts: 29,626
    edited August 2006
    ill sell you mine...
    80+ sh (with box unfinished included)
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited August 2006
    My good friend has a Soundsplinter RL-i8 sub in his trunk. This sub can get loud and stay very clean doing it. People are always amazed when he pops open the trunk and shows them that's it's only an 8" sub that he has. I ran the 10" sub in one of my cars and was very happy with it. I plan on getting the RL-i8 for my newer car.
    Here are a couple of links with some info, as well as a shot from their website. If you have any questions shoot them an email. Mike the owner will answer any questions that you have.
    http://www.soundsplinter.com/rli_ignition_series_8_inch_and_10_inch_diy_subwoofer_drivers.html
    http://www.soundsplinter.com/rli_series/rli_8_inch_DIY_car_and_home_subwoofer_driver_information.html
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • Greg Peters
    Greg Peters Posts: 605
    edited August 2006
  • 1996blackmax
    edited August 2006
    The only thing is that they say it requires one cube of airspace. If space is at a premium, it may be an issue.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • MacLeod
    edited August 2006
    The SR 10 will work down to .7 ft3.
  • 1996blackmax
    edited August 2006
    I know it will, but changing the enclosure will also change the sound. If he wants it to sound like that review, he will have to put it into an enclosure that will be about a cube. The smallest he should probably go would be .88 cubic feet gross.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • Greg Peters
    edited August 2006
    For a 10", that enclosure size isn't huge by industry standards. My current 10" is in a .66 cubic foot enclosure, but that's pretty small for a 10.
    I can't picture an ideal place to build a fiberglass enclosure into a '98 Prelude- never looked in the trunk of one. The anatomy of the trunk may have a spot where a box could be built-in without taking the whole cube directly out of cargo space.
    I agree that 8" subs can put out, too. What we need for this occasion are some SR 8s...
  • 1996blackmax
    edited August 2006
    That would be very nice Greg :).
    The Soundsplinter sub that I had did very well in a .70 cubic foot enclosure. The recommendation was actually .75 cubic feet. The reason I went down some is because at first I was sending a good amount of juice to it. More than the Arc 2100-XXK I had it paired up with later. I was also toying with the idea of getting another one of those subs for my 2002 Maxima. I want the most trunk space available. I am thinking of maybe just shooting for the 8" that I will run in an IB application on my stock 8" location on the rear panel. Decisions.....decisions.....
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • exalted512
    exalted512 Posts: 10,734
    edited August 2006
    The review posted earlier was in a .81ft^3 box
    -Cody
  • 1996blackmax
    edited August 2006
    That is net volume after taking into effect the drivers displacement. So the gross volume is of the enclosure is more. At the bottom of the review he makes a statement something to the effect that says this sub does what he wants it to in a cubic foot enclosure.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
