sub bulding pic 2
goingganzo
here are some more pics of my sub i have a ways to go havent been able to work on it lateley had to go to wa-wa canada witch is a hour north of the soo mi i was camping with the family
the un painted wood will get a high gloss black
Post edited by RyanC_Masimo on
i finaly go to do some more work on my sub here are the pics if you want to see
all the wood on the sub as trim were 2x4 i have riped down to 2x2 ans rounded over the edgeses and sanded alot this is just the primer coat and i still need to do the trim for the other end
Ganzo,
It looks as if you stuffed the sub and it is ported. From my research, sealed subs are to be stuffed, ported are to be lined only.
Peace Out~:DIf...
Ron loves a film = don't even rent. -
it was lined but it is not sticking that good to the sides of the tube but i did put a little extra near the ports i have 30 oz of the polly fill in there
Is this what you're going(ganzo) for?
http://www.geocities.com/manurescape/Jamesdiyspeakers.html?981609316640Make it Funky! -
yeah that is where i got my idea from but i have to change the style of it i amgoing to buld cloth grils for both ends and the color is flat black right now but i have this metalic blue pearlesents paint i am going to put a coat on it it is the paint that you use to paint rc cars bodys and i am going to rap the tube in a blue cloth or a redish cloth the desing i am using is a little diffrent i amusing a tempest sub i have 2 ports and it is 5 feet long and i am makeing it for behind my rear couch becues it is 20 inches away from the wall and there is nothing behind it i am going to use as a tabble also i might buld a seccond one and stack it on top of this one if i like the sound
Ron
Check out the Adire "pre-engineered" designs, they do show using polyfill.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
these are the last to pics i will post till i get it finished the trim is still in flat black and the mdfb has the blue coat over the flat black
