I Need Speaker Recommendations, Please
Early B.
Early B. Posts: 7,900
edited August 2006 in Speakers
I'm on a quest to find a pair of fronts for my HT system. I sort of decided to go with bookshelf speakers for several reasons --
- medium room size
- listening preferences (low to moderate)
- bass is covered by a kick-**** sub
- aesthetics
- mobility
- cost
- WAF
Here's what I'm looking for:
- budget is $500 - $750 new or used (in 8/10 condition or higher); I love to support manufacturers who offer high quality at a great price
- even though I have a kick-**** sub, I want the speaker to go as low as humanly possible for such a small box (I like bass all over the place)
- 6 or 8 ohm (I'll be using a receiver for a while)
- a sensitivity of 88 or higher
- aesthetics: I'd prefer something other than a basic box - maybe something like a tweeter on top or a curved shape
- color: a golden oak or birdseye maple or walnut or rosewood or something a bit exotic (sort of like the Usher X-719 or Polk Lsi9)
- a relatively "large" bookshelf speaker (again, like the Lsi9)
- I would consider an MTM configuration
One of my top choices is a Von Schweikert VR-1. It's kinda basic looking, but it has most of what I'm looking for. I'm also considering going back to a Norh product. I dunno.
Any suggestions would be greatly appreciated.
"God grooves with tubes."
Post edited by Early B. on
    VR3 Posts: 29,416
    edited August 2006
    Tyler Freedom.
  • Early B.
    edited August 2006
    Will 4 ohm bookshelf fronts jeopardize overheating and shutting down my receiver?
    I don't play movies at real loud volumes, if that makes any difference.
  • steveinaz
    steveinaz Posts: 19,545
    edited August 2006
    Energy Connoisseur C-3.
  • Ricardo
    Ricardo Posts: 10,636
    edited August 2006
    Monitor Audio Silver S2...
    http://www.saturdayaudio.com/
    SOPA
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited August 2006
    Do you not run a center channel in your front end for HT. If you do I would think that this would have to be factored into your decision as well. If not, then, don't mind me.
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • Midnite Mick
    edited August 2006
    If you don't mind building I think these would be fabulous. Just a little over budget though.
    http://www.diycable.com/main/product_info.php?products_id=550
    Mike
    Consonance cd120T
    Usher CP 6311
    tonyb Posts: 33,069
    edited August 2006
    Since your always looking for a deal Early,TAD 803.Single driver,no cross over
    easy to drive,and a waf factor up the wazzu.Reviews on Audiogon and the price will please even you,200 bucks.A steal of a deal!:)
  • audiobliss
    audiobliss Posts: 12,518
    edited August 2006
    *salivates uncontrollably*
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Early B.
    edited August 2006
    Mike
    Those speakers are sweet! I didn't see any specs on them, though.
  • tryrrthg
    tryrrthg Posts: 1,896
    edited August 2006
    I've been eyeing the Exodus kits for a while. I want to try building some DIY speakers. There are other kits HERE.
    There are specs on the Exodus Audio 61's
    Also, I pushed my Dyn's with a **** yamaha receiver for about 6 months when I first got them. no issues for me.
  • Early B.
    edited August 2006
    Cool. If I can use 4 ohm speakers, then my choices increase to include the Lsi9.
  • Midnite Mick
    edited August 2006
    Currently, working on the 2641's myself. (sorry a little of topic...enough said)
    Mike
    Consonance cd120T
    Usher CP 6311
  • Early B.
    edited August 2006
    Do you mean you're currently building them or working to buy them? If you're building them, you gotta take lots of pics and post them in the DIY section.
  • Lsi9
    Lsi9 Posts: 616
    edited August 2006
    Hey Early How are you liking those Tylos?
    You havent updated us since your original thread.
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • Early B.
    edited August 2006
    The Taylos are awesome. Greatest speakers known to mankind. ;) I bought them, sold them, then bought them again. They are permanent fixtures on my 2-channel system. I considered using them on my HT system, as well. They sound great as fronts, but I don't want to risk damaging them by carrying them from room to room. The Buggs I'm currently using as fronts are very good, but they're not at the same level of SQ as my center channel. That's why I'm looking for another set of "high end" speakers.
  • Lsi9
    Lsi9 Posts: 616
    edited August 2006
    You sold the Taylos, did you get a more expensive model after? or just the Taylos? any upgrade on the veneer?
    also have you considered Dali speaks they get good reviews
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • Early B.
    edited August 2006
    Nope. Sold them, dismantled my 2-channel system, bought them again, and re-assembled the 2-channel system.
    Never heard the Dali speakers. The Euphonias look nice, though.
  • Midnite Mick
    edited August 2006
    This didn't show up in my new posts until someone posted this morning (Aug. 28).
    I am currently building them. I don't have a digital camera so progress pictures aren't really very convenient but I will be sure to get one for when they are done and provide finished photos.
    Thanks,
    Mike
    Consonance cd120T
    Usher CP 6311
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2006
    Big HT bookshelf, why not the RT55i? Digs to about 45hz -3db. Sounds great especially with rock.
    Just a thought.
    RT1
  • pearsall001
    pearsall001 Posts: 5,258
    edited August 2006
    Early B,
    You know there's only one thing to do to match that superb center you have. Pick up a pair of AAD 2001 monitors!!!!! That would be a truly 1st class speaker system for both HT & 2 channel. I don't think there's much else in their league for the money & even for a lot more. The only problem is trying to find a pair on your established budget. Look under the sofa's for some extra money.
  • Early B.
    edited August 2006
    Early B,
    You're right. The AAD 2001's are what is really want. For now, it's out of my price range. I would need to buy them used anyway and they're probably rarely available (unless you're willing to part with yours, of course;) ). One day they'll be mine.
  • pearsall001
    edited August 2006
    It'll be a cold day in hell before I part with my AAD 2001 monitors!!!! I'll send you a picture if you'd like LOL. By the way where did you pick up the 2002?
  • Early B.
    edited August 2006
    Picked up the 2002 on audiogon.
