Phase wiring for the polks
jrausch
jrausch Posts: 510
edited August 2001 in Technical/Setup
I just bought a pair of SDA 1A's and it looks like the previous user
did some replacements and did not re-wire it correctly. Does Polk use the white wire as HOT/+ or GROUND/-. Any help on this would be very much appreciated. The crosstalk sounds like it's out of phase.
Thanks guys,
JR
"The only way to get rid of a temptation is to yield to it."
Post edited by jrausch on
  • BobMcG
    BobMcG Posts: 1,585
    edited August 2001
    Black goes to positive.
    White goes to negative and to the Blade or bottom of the interconnect socket.
    Blue goes to the Pin or top of the interconnect socket.
    (Your 1-As being twin/blade models is the reason I mentioned the bottom and top socket positions.)
    Remember, the action of SDAs are cancelling out crosstalk distortion, not creating it.
