is one 12 enough?
dickies_04
hey im kinda new at the whole car audio thing, i know my way around with brands, but i have no idea what sub would work for the application. in a small 2 dr car, i want some bass. i dont have alot to spend, around 600$. i want enough bass to rattle it some fierce, if you could tell me some subwoofers and theyre RMS power that would be great. im looking to put just one 12 in, but if that isnt enough for the amount of bass i want then tell me.
NOODLES
Post edited by dickies_04 on
do you have an amp?? and is the 600 just for the sub or for the whole set up? i have a 600 doller budget too and im leaning towards 2 polk mono 15's - 170 each and a 2000 watt profile amp wich is under 200 with shipping on ebay and from what iv heard that is ganna pound pretty good.:D
i check out the square kickers (cc sells them in the box already). if your looking to save truck space they are as loud as 2 regular 12's. but $$$400 for one. id buy em if i could start over...
Thats a good idea, if youre just wanting to throw something in the trunk and get attention, run down to CC or BB and check out their premade boxes. That would be a lot easier.polkaudio sound quality competitor since 2005
