Omni-mount 10.0 Speaker Brackets
soiset
I bought 4 Omni-mount 10.0 Stainless Speaker Brackets, and after opening one, figured out that I wasn't going to be able to use them. I had intended them for my LS f/x, but couldn't find any way to adapt them to the 3/8 x 16 threads in the bottoms of the cabinets. I put all the bits from the one I opened in zip-loc bag, but the other three are in original packaging. Because I bought them on clearance, I cannot return them to the store. Go here to see what they look like:
http://nst.mountsandmore.com/asp/show_detail.asp?sku=OM0064&catid=218
I'll send them at these rates, shipping included:
1 bracket: $18
2 brackets: $32
4 brackets: $54
1 bracket: $18
2 brackets: $32
4 brackets: $54
1 pair gone to ViperZ, one pair remain. The second pair includes the mount that has been opened, with all pieces accounted for and in a zip-lock bag.
This might set the record for longest running for sale thread in the flea market!!!!!!!
ShawnShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
shawn474 wrote:This might set the record for longest running for sale thread in the flea market!!!!!!!
Shawn
I guess the search tool for this forum, though very weak, makes a hit every now and then. -
Yep, but that's a good thing, I guess. The fact that you sold an item almost ten months after posting - in this case, I'm a firm believer in better late than never.
Shawn
Front: Polk LsiM703
Rear: LSI fx
Received the brackets today. They are as described - never opened. Thank you!Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
