Do Amps Lose Power over time?
Drastlin
Drastlin Posts: 18
edited August 2006 in Electronics
I bought an adcom 5503 off ebay that is about 8 years old and it sounds great. The question is do things like capacitors and other components that run the amp slowly degrade over time. Can you have a technician look at the amplifier and maybe replace the parts that go out over time? Any information would be great!
Post edited by Drastlin on
  • George Grand
    George Grand Posts: 12,258
    edited August 2006
    You're in luck. I myself, run a "home" for amps that have basically outlived their usefulness. At eight years old, your amp is well into its "golden years" if you catch my drift. As one of your new audio advisors, I can't suggest strongly enough that you send me that amp and spare it some of the indignities that can accompany the advance of old age. Here, at my "amplifier preserve", it will see other amps, and sometimes speakers too. All at no charge to you, except for the initial shipping.
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2006
    Unless the capacitor is leaking, bloated or the top is popped off...don't worry about it. This is not a common problem in modern electronics.
    I think you should send it to George.
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2006
    Simply priceless!!!!!:D :D:D:D:D:D:D:D:D:D:D
  • Drastlin
    Drastlin Posts: 18
    edited August 2006
    Heh, no way this old foggie going to get any rest any time soon. Just gonna have to push him till he blows.
  • madmax
    madmax Posts: 12,434
    edited August 2006
    The 5503 uses 30 MOSFETS, 10 per channel. These are wired in parallel. Each one handles maybe 20 watts each. If any of these go bad the remaining ones still do what they are supposed to but if one goes bad then you will be down 20 watts, two bad then down 40 watts and so on.
    So, the quick answer is yes, with this type of amplifier you can have a loss of power over time even though it appears to work fine.
    madmax
    Vinyl, the final frontier...
  • venomclan
    venomclan Posts: 2,467
    edited August 2006
    They must live the good life there, taking turns powering Matrix demos and trying on different IC's for the latest fashion trends...
    If it is any comfort to you, mt Adcom 535 circa 1994, is still running great.
    Venom
    heiney9 Posts: 25,432
    edited August 2006
    Venom
    As is my Adcom GFA-545 which I bought new in 1986. Most modern electronics if used consistenly and not abused will last a very long time. Adcoms, among many other amps, are built like tanks which usually leads to a long trouble free life.
    No worries.
  • dorokusai
    edited August 2006
    madmax
    I'd bet money on a capacitor failing before a transistor, especially in vintage gear...and we're not talking vintage gear. I presume that means your replacing all your transistors next week?
    I agree that the breakdown of the design is segmented, for a reason, but I have yet to replace a transistor to spec an amplifier. If it needed a FET, it was slagged anyways.
    F1nut Posts: 51,776
    edited August 2006
    madmax
    A factual, to the point answer to the question asked. Bravo!
  • Flash21
    Flash21 Posts: 316
    edited August 2006
    We are using my first real stereo receiver, a mid-70's vintage Realistic with a real wood case and a big flywheel tuning knob, rated at a sizzling 16 watts/channel, at our lake cabin... that thing still can rock out when desired...solid state lasts a long long time.
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
