A few questions about front projectors
millerman 3732
I'm thinking of replacing 60'' lcd rptv with a front projector set up. its about 15' from the seating position to the wall so I think i could put at least a 80'' or 92'' screen on the front wall, but I have NO experiance with projectors and do not know the first thing about them so I am looking for a little help here.
1. How practical are they for just watching T.V. SD an HD?
2. Is turning one on a big deal? will I have to wait 15 min for the bulb to warm up or say if I mistakenly turned it off how long will I have to wait to turn it back on?
3. can I control one with my remote, off and on?
4. how long do they last?
5. are you happy with your projector or do you wish you had went another direction?
6. can they be veiwed in normal light or will I have to completely black out the room? this is my main concern.
Thanks for any info that you might give and if there might be something else I need to know or might have over looked please let me know.
Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Post edited by millerman 3732 on
I've been using a Sony VPL-HS20 for almost 2 years and am still on my first bulb...approx 3800 hours so far. The manufacturer says to replace it at 2800.
The front row is at 12' from the screen (106" diag.) and the picture is breathtaking.
I've programmed my MX-500 to control the projector.
Bulb warm up time is under 30 seconds and cool down takes about a minute.
Our HT is very dark but the picture can be viewed in dim light without too much loss of brightness.
Deb surprised me the other day when we were talking to someone about our HT and the big-**** screen. She originally thought I ws completely off my rocker when I wanted to install the FP. She didn't think watching the local news in SD on a huge screen was something that was going to work too well. Now she admits that it's a huge improvement over our "old" TV (Mits 55" W.S.)
Go for it, you won't be disappointed. -
thanks for the input Frank, Is your setup in a dedicated media room or a family/living room type enviromentCasey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Polk Signa-1 Surround bar -
Had to dig a little, but this is what mine looks like.
http://www.polkaudio.com/forums/showthread.php?t=16726&highlight=latest -
looks great Frank love the color you picked but wheres your sub?Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Take a look behind the left main speaker in post #2. It's curently between the rack and the left main. It's a Sunfire TrueSub EQ, so it's hard to see.
what kind of mounting options do you have with a projector does have to be dead center of the screen or can it be offset to the side? how far away does the projector need to be from the screen? what is the native resolution of your sony vlp-hs20 and how do you think it compares with other displays you have seen? sorry about all the questions but I new to all this.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
I have a toshiba TDP-S25 Projector and a Da-Lite 80x60 Matte white screen. I like to combo for the time being till i get a house and can have a home theater room.Samsung UN46C7000
Cambridge Audio 640R
Sony BDP-S570
Magnepan MMG's
Totem Dreamcatcher Center
Eleganza Bella 1200 High Performance Subwoofer
Polk R15 Surrounds
Audioquest Cables
Panamax 5510-PRO AC Regenerator
Monster Cable HTS 2500 MKII power cleaner
Nordost Blue Heaven Interconnects -
Thats great I'm glad that your enjoying you set up. How do have your projector mounted?Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
I bought the Sony mount and have it approx. 15' from the screen. I do have a keystone correction feature that allows for setting the projector off center. The resolution is 720p....HD programming is freakin' amazing.
I looked at a few locally but most of them were $10K or more at the time that I bought mine. Most of the ones I saw were DLP and had really nice picture quality, some looked like crap. I attribute that to lousy set up, not poor performance. I've been very happy with the Sony and it actually cost less than my Mits. did.
Here's a link that you find useful for determining the distance from the screen...
http://www.projectorcentral.com/projection-calculator.cfm -
thanks Frank your alot of help!Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
You're Welcome.
How far off set does the the correction feature of your projector allow for? the spot that I had hoped to mount it is 13.5' from the wall and 6.5' offset from where the center of the screen would be is this to much? this location I know isn't the ideal spot but it would be the easiest on me no drilling or cutting.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
When projecting a 480i/480p picture:
Using the keystone adjustment and side shot adjustments, the projector can be offset by 3.3' with a 100" screen with an aspect ratio of 16x9. There's a few charts in my manual that show a wide variety of offset distances vs. screen sizes. Another axample would be having the projector even with the horizontal centerline of a 100", 16x9 screen, the offset can be 15.4'
1080i/720p
The offset is less.
I would suggest auditioning a few projectors and pay particular attention to the manufacturers installation instructions. All of the data is there. -
Mine is sitting on a shelf may be ceiling mounting it soon. It is centered and 14' away from the screen.Samsung UN46C7000
Sony BDP-S570
Magnepan MMG's
Polk R15 Surrounds
Audioquest Cables
millerman 3732 wrote:I'm thinking of replacing 60'' lcd rptv with a front projector set up. its about 15' from the seating position to the wall so I think i could put at least a 80'' or 92'' screen on the front wall, but I have NO experiance with projectors and do not know the first thing about them so I am looking for a little help here.
1. How practical are they for just watching T.V. SD an HD?2. Is turning one on a big deal? will I have to wait 15 min for the bulb to warm up or say if I mistakenly turned it off how long will I have to wait to turn it back on?3. can I control one with my remote, off and on?4. how long do they last?5. are you happy with your projector or do you wish you had went another direction?6. can they be veiwed in normal light or will I have to completely black out the room? this is my main concern.
Prewire is the one biggie you haven't mentioned. May be a problem if no access to the walls. -
wallstreet wrote:SD, fogetaboutit. PQ is bad at 36", at 106" unwatchable..
Frank Z wrote:Untrue.
I watch SD material on my 106" all the time, not as good as a DVd or HD, but still watchable.
SD watchability has more to do with good cable/dish/antenna feed than resolution issues. Faroudja or other top line doubling chips in some of the projectors can help with SD too.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
At my normal viewing distance of 13 ft with a 100" diag screen, SD looks pretty bad. If I move a few ft back, it is much more watchable. I don't know if this is a limitation of the projector or source (Time Warner digital cable with HD box). SD looks better on my parents' 60" SD rear projection TV. I don't use my projector for SD, other than when a Bengals game is not in HD.
HD picture quality is phenomenal - definitely better than what I've seen on the TVs in Best Buy or Circuit City (but the HD feed could be part of the problem there).
My projector is in my basement, where I can control 100% of ambient/daytime light. It can tolerate a low amount of ambient light, without washing out the picture too much. However, normal daytime light would be a problem and would limit use to nighttime.
Some projectors have a lens shift that gives you more vertical and horizontal mounting flexibility, without the need to use keystone. The lens shift specifications/calculations will tell you if it's adequate for your needs.
I was a total projector newbie before I bought mine in June '05. As mentioned above, projectorcentral.com is a great place to learn and research models.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
With the cost of bulb replacements, I don't watch anything but dvd's on my projector. I got a 50" Sony RP for TV viewing. As far as being 6' off center, don't know if many FP can handle that much of an offset. Your best bet may be to look into a FP with lens shift. My Sanyo has it, but I've never took it to the extreme left or right. Projector central is a great place to get info on projectors. And good deals too.
