125 watt amp suggestions
jimi64
looking for recommendations for a 2 channel amp for the top end for my RTi 12`s.Currently running a Onkyo 282 for the top end-looking to mellow out the tweeter`s(brightness) thnx
Post edited by jimi64 on
Parasound Halo A23 125w x 2 nice amp, but since you haven't stated a budget this could be a little pricey.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
thnx-I`ve been thinking about those-seem to have a rep fot running hot tho.budget?-thinking about a 2 chanel tube amp for top end-suggestions?
They do run a little warm during normal listening, but when pushed run a bit hot... They never change sound either way and love to push them showing off.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
I am looking for something in the same range i think i may go towards Rotel or someting of the sort.Samsung UN46C7000
Cambridge Audio 640R
Sony BDP-S570
Magnepan MMG's
Totem Dreamcatcher Center
Eleganza Bella 1200 High Performance Subwoofer
Polk R15 Surrounds
Audioquest Cables
Panamax 5510-PRO AC Regenerator
Monster Cable HTS 2500 MKII power cleaner
Nordost Blue Heaven Interconnects -
Rotel should do it, a warm sounding amp. Also look into a used Adcom 535, it is underrated at 60 watts but is very smooth.
Venom -
If you folks can offer solid suggestions based on the original information, rock on.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
jimi64 wrote:looking for recommendations for a 2 channel amp for the top end for my RTi 12`s.Currently running a Onkyo 282 for the top end-looking to mellow out the tweeter`s(brightness)
Nature of the beast. IMO, if you want mellow, try a different speaker.Political Correctness'.........defined
President of Club Polk -
First of all, let them break in, if you haven't already. I've had RT(i) tweeters begin to change after 40-50 hours, and break in completely nearing 150 hours of use, at normal listening levels.
Second, the Onkyo isn't the smoothest amp out there, changing to a better amplifier will not only improve the brightness on the top end, but help with midrange and bass control also.
Third, make sure the jumpers are off the back, by using either a bi-wire cable, or a short run of speaker wire. After your amp upgrade, upgrade speaker cables to match. Which ones should you buy? GOOD ones. You've got decent interconns, bravo - now finish the rig out.
The 12 is a fine speaker, and very capable and balanced for critically listening to music.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
I would give you two more suggestions if Russ' suggestions don't do it for you:
First: Sell the Oink and use the money from it and what you would spend on the second amp for a single upgraded amp. Biamping to get more power is, well, you can do a search on it and find out.
Second: If your stuck on Bi-amping: Look for a >20W tube amp. Trust me that 20W to a tweeter/mids will give out way after your amp to your woofers has given up the magic smoke. It will sound especially sweet adding: http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=266-272
before the tube amp to clear out some of the bass signals. You could add a low pass at 150Hz to your bass amp as well to keep some harmonics down.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
