B&k Avr 305
criverajr
criverajr Posts: 1,675
edited August 2006 in For Sale (FS) Classifieds
Polksters,
I have a B&K Avr 305 7.1 capable reciever for sale. The unit is black with no dings, scratches, dents. Come with original box, remote and manual. I purchased this from a authorized dealer, works great sounds fantastic, no issues, it drove my LSI series speakers with no problem, before I switch to Rotel seperates. It;s price for selling 900.00 which will include insured shipping. This is 5 x 150 @ 8 Ohms but again had no problem with the LSI Series. 850.00 if picked up in Jersey.
AVR305 delivers today's cutting edge technologies and performance all at the touch of a button. Dolby Digital ® , THX ® , DTS ® , 6.1 Surround, 7.1 Surround, Surround EX ® ,
RECEIVER SPECIFICATIONS
5 years receiver
1 year remote
Warranty:
See Limited Warranty
65 pounds Weight: 95 dB S / N (A-weighted):
17"(w)x17"(d)x7.50"(h) Dimensions: 1.4 dB Dynamic headroom:
Rails - 6 Amp/250 Volt (slow blow type) 14 V/msec Slew rate:
Line -12 Amp/250 Volt Replacement fuses: 28 Amps Current (peak to peak):
31 watts standby 150 Damping factor:
(10 amps @ 120 V) 0.09 % @ 1 kHz THD (S + N):
1200 watts max Power consumption: 5 Hz - 45 kHz Frequency response:
120/220/240 VAC Line voltage: 150 watts @ 1 kHz Power rating: 8 ohms:
Miscellaneous Amplifier Specifications
300 Ohms Antenna Input Impedance: 75 Ohms Antenna Input Impedance:
70 dB, A Weighted Signal to Noise Ratio:
30 dB Selectivity: 65 dB Alternate Channel Selectivity:
28 dBf Sensitivity: 15 / 35 dBf Mono/Stereo Sensitivity:
12 dBf IHF (Usable) Sensitivity:
2 dB Capture Ratio:
28 dBf Sensitivity: 20 Hz - 15 kHz, +1/ -3 dB Frequency Response
Less than 0.3% Total Harmonic Distortion: Less than 0.25% Total Harmonic Distortion:
520 - 1670 kHz Frequency Range: 87.5 - 107.9 MHz Frequency Range:
AM section Tuner Specifications FM Section Tuner Specifications
6, 12 or 24 dB/Oct Low Pass Crossover Slope
6 or 12 dB/Oct High Pass Crossover Slope
Adjustable 20-200 Hz High/Low Pass Crossover Fc
1 Component Video Outputs 1/1 (Zone 1), 0/1 (Zone 2) Digital Outputs coax/optical
2 Component Video Inputs 6/5 Digital Inputs coax/optical
5.1 format Multi Channel Input
5 SVHS Video Outputs 4 Audio Analog Outputs
7 SVHS Video Inputs 7 Audio Analog Inputs
5 Composite Video Outputs 8 Surround Outputs
7 Composite Video Inputs 46 mV Noise Test Reference Level:
75 Ohms Output Impedance: 221 Ohms Output Impedance:
75 Ohms Input Impedance: 50 k Ohms Input Impedance:
98 dB CCIR 2 k Weighted Signal to Noise Ratio:
2 V P-P Maximum Output Level: 3 V rms Maximum Output Level:
2 V P-P Maximum Input Level: 2 V in, 1.5 V reference out Input Sensitivity:
20 Hz - 10 MHz ±3dB Frequency Response: 5 Hz - 20 kHz, +0/-0.5dB Frequency Response:
Video Specifications Audio Specifications
Specifications subject to change without notice
77 p/n 12858 Rev. 0717A
CRj
Post edited by criverajr on
