Help - Buying Polk Speakers - Need advice
I am poised to buy RTi8's(front), Rti6's (rear), CSi5(center) and a PSW404 (sub). Are these a good match? Will a Denon AVR2807 100wpc amp be enough to push this system?
Any help would be appreciated.
Thanks in advance.
Thanks in advance.
Post edited by Stegar98 on
Stegar,
Your setup looks good. A Denon receiver always goes well with polk. The speakers are all voice matched as well.
Although, If I could change anything, I would vote for a nicer sub. If that's all that's in your budget, than go for it. But if you can swing it, that would be my first upgrade. -
Good setup. Which do you listen to more - movies or music? If music, is it multichannel music? If multichannel, I would match the front and surrounds exactly - that is buy rti8 surrounds, too, insead of the 6s. I movies, you've got a good setup. I don't have any exp. with that sub so can't comment on it.
The 8s will benefit from more power than you're going to give them, but they'll sound great nonetheless.HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee
