Electricians? What's up with my two-way switch?
cnjvh
cnjvh Posts: 253
edited April 2024 in Clubhouse Archives
K I got a two way switch controlling the lights in my hallway (3 separate fixtures). The switches work fine, but it seems that once a single light burns out, the rest of the lights in all the fixtures burn out within the next few days. I suppose one could say that since I'm replacing them all at the same time they should all burn out around the same time, but I don't quite buy that. Any electricians here? Is this normal (like maybe once one bulb blows they are all dropping extra voltage in the circuit)? Guess that only applies to series circuits though :confused:
No earth robot is going to tell ME which button to press!!
--Stuff--
Front: Polk Audio RTi12
Center: Polk Audio CSi5
Surrounds: Polk Audio RTi8 (x4)
Sub: SVS PB10-ISD (Dual)
AVR: Denon AVR-3805
Blu-Ray: Panasonic BD30
Display: Sony KDL-55NX720B
STB: Xfinity X1DVR
Post edited by RyanC_Masimo on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited August 2006
    Who would think that 3 lights of the same kind, from the same manufacturing batch, on the same electrical circuit, replaced at the same time to have relatively similar life spans?:rolleyes:
  • cnjvh
    cnjvh Posts: 253
    edited August 2006
    Relatively similar? Sure - I'll buy that. But given the long life span of a bulb, isn't having them all go out within two days of each other a little weird?
    --Stuff--
    AVR: Denon AVR-3805
    STB: Xfinity X1DVR
  • Dennis Gardner
    edited August 2006
    I've got a 4 bulb and a 6 bulb bathroom fixture that seems to always do the same thing. It has gotten to the point that when I notice a bulb out, I go ahead and change it even though 1 or 2 bulbs doesn't really affect the output of so many lights in those fixtures. Going to a higher quality bulb also helped in the rotation of them.
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    edited August 2006
    I like you analogy, and it may be related to your problem. If the bulbs were run in series on your circuit, and one blew then they would all go out, much like some christmas lights. So I would suppose that if the circuit is in parallel, and you look at your bulb as a resistive load, then your resistance decreases then the current through the fixture is increasing as your voltage remains a constant.......
    Anyway...
    Just keep some extra bulbs handy in the cabinet and replace as needed..
    Scott
  • cnjvh
    cnjvh Posts: 253
    edited August 2006
    Alrighty then...I'll consider this normal (at least until my house is reduced to red hot glowing embers).
    Thanks all :-)
    --Stuff--
    AVR: Denon AVR-3805
    STB: Xfinity X1DVR
  • amulford
    amulford Posts: 5,020
    edited August 2006
    Well at least then you won't need the light bulbs, for a little while anyway...;)
  • cnjvh
    cnjvh Posts: 253
    edited August 2006
    :eek:
    No, just weiners and marshmallows.
    Guess I should look into those LED light bulb thingys anyway...
    --Stuff--
    AVR: Denon AVR-3805
    STB: Xfinity X1DVR
  • mrbigbluelight
    mrbigbluelight Posts: 9,896
    edited August 2006
    Thanks all :-)
    If we're wrong, let us know after you establish internet service in your new house. Or homeless shelter. Which ever comes first.
    :rolleyes:
