Denon AVR-2807 and PSW-10
deeplfo
deeplfo Posts: 4
I was reading this site's sub connection article, but since I didn't know when how long ago it was written I thought I'd ask my question here:
the Denon has both pre-outs for all the speakers as well as the sub out. What is the more preferred connection in this case:
1) Denon sub out to PSW's line level in
2) Denon's pre-amp front L/R speaker out to PSW's speaker in and then fanned out to the actual front speakers?
Thanks,
mohsen
Post edited by deeplfo on
  • Ern Dog
    Ern Dog Posts: 2,237
    edited August 2006
    When I had the PSW10 I went with option #1 and it sounded good. Try them both out and see what you think sounds better.
  • deeplfo
    deeplfo Posts: 4
    edited August 2006
    The only reason I can't do that is that I need to decide which route to take since all the wiring is going to be in-wall, since these are things I am doing before sheet rock goes up in our remodeling project :-)
    mohsen
  • frodaddy
    frodaddy Posts: 124
    edited August 2006
    Sub out is the best way
    Fronts: DIY Statements from htguide.com
    Center: DIY custom Statement center from htguide.com
    Surrounds: Four DIY custom Mini Statements
    Wire: HD-14
    Receiver: Denon AVR-4806 + CI upgrade
    Amps: Dual Emotiva LPA-1's
    Sub: Infinite Baffle: 8 fiCarAudio IB315 woofers, Behringer DSP1124P EQ, Elemental Designs eQ.2, Dual EP4000 amps
    Transducers: 2 buttkicker LFE's, BK amp, EQ'd w/DSP1124p
    DVD: Toshiba HD-XA2 / PS3
    TV: Samsung 1080p 61" DLP
  • deeplfo
    deeplfo Posts: 4
    edited August 2006
    Thanks, I'll go for that. Now the question I raised in some other thread, what's the recommended cable to get subs or other line levels connected inside walls? RG6, shielded 2-conductors, all CL3 rated...??? any advise?
    Thanks,
    Mohsen
