LSiC center with RTi10 setup?
stubro
stubro Posts: 21
edited August 2006 in Speakers
Ok I need some help here. I have a space issue. I have ordered a set of RTi10s, FXi5s(4), and a CSi5 but my new entertainment center has a slot for the center channel that is only 7" high which i believe the CSi5 wont fit. I am going to try it when it gets here hoping for some space but if not I need to know can I, or is anyone, using the LSiC with their RT setup? My amp can handle the different impedance but I am concerned about the matching. Any thoughts? I really dont want to step down to the CSi3.
Post edited by stubro on
  • Frank Z
    Frank Z Posts: 5,860
    edited August 2006
    Stick with the CSi5. Put the speaker either on top of the unit or below the TV and then use some rubber door stops to angle the speaker toward your listening position.
  • Early B.
    Early B. Posts: 7,900
    edited August 2006
    Yep. Find a way to make the Csi5 work for you.
    "God grooves with tubes."
  • aaharvel
    aaharvel Posts: 4,489
    edited August 2006
    If the csi5 doesn't fit, get the csi3.
    You don't want to mix and match the front soundstage with rti/lsi lines.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • AndyGwis
    AndyGwis Posts: 3,655
    edited August 2006
    I have a CSi3 (black) that I may be looking to unload. If you go that route and don't mind a like new (boxes, warranty card, perfect condition, etc.), maybe we can work something out.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • OpticalSerenity
    OpticalSerenity Posts: 92
    edited August 2006
    I just upgraded from a CSi3 to a CSi5, and while I can tell a difference, you'll be very happy with the CSi3. The CSi5 though does come with a bar that'll help you angle it.
  • stubro
    stubro Posts: 21
    edited August 2006
    Well I think the wife is going to allow the CSi5 to be ontop of the unit through now I think I have to mount the flat panel in response. Thanks for all the adivce on this of course the sales guy said I could step up to the, more expensive LSi, with no wounds loss. :)
  • OpticalSerenity
    edited August 2006
    Of course! Everytime I go to tweeter they are more than happy to bump up my RTi setup to the LSi system.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited August 2006
    I agree. No LSIC....unless you want to get all LSI....;)
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
