receiver shut off last night please help
Home Theatre
Home Theatre Posts: 469
edited August 2006 in Electronics
So I was listening to some music last night. Loud but not crazy.
All of a sudden the receiver shut off. Turned it back on again with the volume lower and everything was fine. I felt the receiver and it was really hot.
Anyone ever have this problem? Also on the receiver it said check speaker wire. Any suggestions? I had another receiver say system overloaded but that was only when I hooked it up to Cerwin Vegas.
Any help would be great.
The receiver worked has worked fine all day.
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
  • Mike682
    Mike682 Posts: 2,074
    edited August 2006
    If the receiver said check the wire, most likely the wires are touching each other, creating a short and causing the amp to overload at higher volumes.
    Check the wires (both at the back of the receiver and at the speaker) to see if they are touching and adjust accordingly. Also give the wires a complete check for any exposed areas between the receiver and speakers
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2006
    One of the main reasons why I like banana plugs, you don't have to worry about stray wires touching!
  • Frank Z
    Frank Z Posts: 5,860
    edited August 2006
    Proper clearance above receiver?
  • Home Theatre
    edited August 2006
    There is really no clearance should I invest in a new stereo cabinet or a fan?
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2006
    Frank most likely nailed it...heat. If you can't reconfigure the rack, pick up a cheap "clip-on" fan from Target, or wherever, and use that in the interim to blow/draw air from that area.
  • Frank Z
    edited August 2006
    Crack open the owners manual and yopu'll find that the manufacturer has a minimum clearance printed near the front. Typically it's 6-8 inches.
    A muffin fan and open doors will help.
  • unc2701
    unc2701 Posts: 3,587
    edited August 2006
    Yeah, Yamahas show "check speaker wire" for thermal shutdowns... usually the problem is heat caused by too much current going through a short in the wires or low impedance speakers but you could trip it by not enough clearance.
    Backburner:Krell KAV-300i
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2006
    :eek:
    Polk Patrol lends help to yet another soul.:)
    RT1
