How high surrond speakers
Andrew2112
Andrew2112 Posts: 59
edited August 2006 in Speakers
I'm getting a new pair of FXI5's tomorrow and I'm really pumped because it will be my first experience at home with surround speakers. I have a vaulted ceiling and considering the location I'm planning on putting them (behind me) the wall runs from 14 feet to 16 feet. My question is should I go high 7' or 8' or should I go 'low' 5' to 6'?. They would be 12 feet behind me as my front speakers (RTI8, CS400i, PSW505) sit 12 feet in front.
With my new 61" 1080p DLP tv it will be a while until I step into a movie theater!
Thanks in advance guys.
Post edited by Andrew2112 on
  • Frank Z
    Frank Z Posts: 5,860
    edited August 2006
    Put them on the side walls with the tweeters 2-3' above the listeners ear level.
    Don't forget to calibrate with an SPL meter.
    http://www.audiophilia.com/hardware/spl.htm
  • Andrew2112
    edited August 2006
    With the layout of my living room side placement is not an option but thanks for the quick response.
  • ohskigod
    ohskigod Posts: 6,502
    edited August 2006
    as long as they are at least ear level, it will fly. I have mine on 24" stands, and that is the lowest placement I would remotly consider. I would like them a little higher, but its no emergency.
    but if your doing 5.1, you want them pretty much on the side even with your head, maybe a little further back, not on the back wall.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited August 2006
    I have mine a whopping 4' above ear level as I really have no choice due to my room layout and it sounds just fine. If you think about it, when you go to the movies the surrounds are what...10 feet or so above ear level? I believe for home HT though about 2 feet would be ideal.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Toxis
    Toxis Posts: 5,116
    edited August 2006
    2-3' above ear level = ideal.
  • danger boy
    danger boy Posts: 15,722
    edited August 2006
    they are recommended to be 2 to 3 feet above your head/ears for best placement. i think you can fudge that a little.. but don't go below that.
    PolkFest 2012, who's going>?
  • univera
    univera Posts: 848
    edited August 2006
    My thoughts exactly in regards to movie theaters. Movie theater sounds pretty damn good way up there...Mounting down low, unless it is inwall, doesn't look to hot. If I may latch on to this thread, is there a general consensus on placement when the back wall is the one where your couch is positioned. I have one inner, half wall (that extends from the rear wall) pretty even with my left, front main and the other side wall of the house is a few feet wider than my right main. I am sitting against the back wall. What's the ideal spot to mount my surrounds?
    UNIVERA
    Historic Charleston SC
    2 Channel:
    SDA-SRS's RDO tweets
    Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
    Anthem Pre 2L w/E.harmonix platinum matched 6H23's
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
    DVD: Toshiba 3109 dual tray
    Subs: Velodyne and M&K
    T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
    Conditioner: Panamax M5100EX
    Master Bedroom Sony 40KDL-XBR3
    "I love it when a plan comes together." Hannibal Smith, The A-Team
  • Andrew2112
    edited August 2006
    Thank you all for your input. I got the FXI5's today and ...damn they are big and extremely good looking.
  • Toxis
    Toxis Posts: 5,116
    edited August 2006
    I prefer them lower than higher than the recommended. Mine are about a foot above ear level (more for SACD purposes though) and love it.
  • Schwingding
    Schwingding Posts: 363
    edited August 2006
    I'd say it depends on what you are listening to - movies or music. Movie effects are well suited towards moving the speakers a bit above head height. However, multichannel music seems to be best when the tweeters and mid ranges are all at ear height. You mentioned movie theater so I assume that is your pref. Put them a bit higher.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • Skynut
    Skynut Posts: 2,967
    edited August 2006
    MIne are mounted on my vaulted ceiling just behind the sweet spot. They fire down toward the back of my head and sound pretty good.
    I also do not have the side option.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • scottnbnj
    scottnbnj Posts: 709
    edited August 2006
    i don't really do ht, but fwiw i stumbled across this article last night:
    http://www.acousticsciences.com/articles/ht-4.htm
    i didn't really read it closely, but noticed it touched on some concepts that don't talked about much.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited August 2006
    I agree with the 2 to 3 feet. This comes from experience. I did about 5 feet above listener level once and I hated the results.
  • MattN03
    MattN03 Posts: 558
    edited August 2006
    Great info, as I should be receiving my FXi5's next week :)
  • MattN03
    MattN03 Posts: 558
    edited August 2006
    Any pics of your arrangement?
  • josh_parsons626
    josh_parsons626 Posts: 219
    edited August 2006
    Ideally, in a perfect world if you're about a 6' tall man mount them eye-level about 2' from the side wall.
    Don't forget to look at My Home Theater :D
    Receiver - Onkyo TX-SR503
    Fronts - Polk Audio Monitor 40
    Center - Polk Audio CS1
    Surrounds - Paradigm Cinema ADP
    Subwoofer - Velodyne VRP-1200
