Rotel delay
opus
Hey guys and gals,
I have noticed today that I have a pretty severe delay when watching tv/sat and running them thru my Rotel pre. I really noticed this watching a San Fran Cisco car chase and you could hear the car hit the pavement well before you could see the car hit the ground. Maybe a 1/2 a second. Do I make up for this delay in my speaker setup? I can't find any other setup options that might address this. If I do use my speaker delay could you walk me through it like a 4 year old. My eyes kinda glaze over on stuff like that.
I'm running f/o from the dish to the rotel and dvi from the dish to the tv if that helps any.
thanks....kevin:)
thanks....kevin:)
The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre)
-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable
Hitachi 50VG825 LCD
LsiC, Fxi30's
Post edited by opus on
Does the 1066 have the lip sync option in the menu? I know my 1068 has it. That may fix the problem.
del44 wrote:Does the 1066 have the lip sync option in the menu? I know my 1068 has it. That may fix the problem.
I don't think so but I will recheck. It's not on the OSD. Time to dig out the manual.
thanksThe Flea rig
Hitachi 50VG825 LCD
-flea market
LsiC, Fxi30's
Signal Cable and Kimber Kable -
I've seen it on my set-up. It has never done it with a DVD, so I know it's Comcast and it's only a very small percentage of the time.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
I-SIG wrote:I've seen it on my set-up. It has never done it with a DVD, so I know it's Comcast and it's only a very small percentage of the time.
Wes
So your saying to fix the delay on the satelite side? Good idea. I will try it. And yes it only happens with satelite and not DVD.The Flea rig
Hitachi 50VG825 LCD
-flea market
LsiC, Fxi30's
opus wrote:So your saying to fix the delay on the satelite side? Good idea. I will try it. And yes it only happens with satelite and not DVD.
I don't know how you would go about fixing it on the source side. I just knew that I have my system wired the same whether it's cable or dvd. (video straight to the plasma; audio straight to the preamp-amp-speakers)
Therefore, if I got delays with one and not the other, then my system wiring is the constant so it can't be me.
