Allways on vs Auto on
Ruin
Ruin Posts: 59
I was wondering what the advantage to using Auto on vs Allways on is for powered subs. I would not think the amp is doing much if there is no signal even when always on, but I could be wrong. It does seem to me though that on/off cycling is bad for all electronics so would it be better to use allways on and save wear and tear on the amp section of the sub?
Anyone know anything about this?
Thanks!
Ruin
Denon AVR4806CI
Denon DVD3930CI
Panamax 5500-EX
Polk LSi25 mains/subs
Polk LSiC center
Polk LSi9 Surrounds on Custom Skylan stands
Mitsubishi WD-65831
Audio Art IC-1 Interconnects
Audio Art SC-5 Speaker Wire
Post edited by Ruin on
  • polrbehr
    polrbehr Posts: 2,854
    edited August 2006
    I used to leave my PSW450 on all the time, but the heatsinks were always
    warm to the touch even in standby mode, so I now plug it into a switch controlled outlet, and it's only on when the rest of the system is on.
    From what I understand, leaving the sub on all the time will ensure no dropoffs or delays whenever a DVD or CD is played, but I can't imagine it would make that much of a difference if left in standby? I doubt there is much wear and tear on the amp, but I could be wrong about that. I would say leave it in standby though; it's not really "on" til a signal is received.
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2006
    I've run subwoofers both ways and never noticed a difference in lifespan or performance. I currently use "Auto-On".
  • TheReaper
    TheReaper Posts: 636
    edited August 2006
    I always leave my sub-woofer on, because I don't always have a strong enough signal to trigger the auto-on. I do a lot of low volume listening, and my normal sub-woofer level is -7 (gives me the freedom to temporarily boost the sub-level up using my remote).
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • ronnie
    ronnie Posts: 150
    edited August 2006
    i keep my subs in the always on position....sometimes im not listening loud enough to activate my subs....turn it up a bit and boom my sub comes on...hate when that happens....so im always ON
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Yamaha CD685 cd changer
    Yamaha Dvd c950 dvd changer
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    Polk RTi6 (surround and surround back)
    Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
    WindyWillys cooling fan (works great)
    Mitsubishi 52in big screen
    blue jeans cables
    AR interconnects
  • OpticalSerenity
    OpticalSerenity Posts: 92
    edited August 2006
    Interesting, I didn't realize that low volume could lead to them not coming on in the "auto on" position. Thanks.
  • SKsolutions
    SKsolutions Posts: 1,820
    edited August 2006
    Is there a switch like this for the fairer sex?
    -Ignorance is strength -
  • michael_w
    michael_w Posts: 2,813
    edited August 2006
    Yeah there is but it works the other way around (auto off - usually caused by a gassy signal ;) )
    I think the only reason people don't use auto-on is if they have a sleepy sub (as in it shuts itself off easily when listening to quiet movies or music). I personally use auto-on just because I get a little bit of hum when my sub is on and like to get rid of that persistant noise when I'm not listening to music. Either way, my amp gets warm even when I'm not using it.
  • Skynut
    Skynut Posts: 2,967
    edited August 2006
    Auto on here but I do notice my Sherbourn amp stays warm, in fact my whole rack stays warm.
    If I could find a decent switched outlet for everything I would use it.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • Willow
    Willow Posts: 11,297
    edited August 2006
    FWIW, I use auto on, with my current set up. In the past I did have issued with a particular system, not receiving the signal on time so I left it on all the time.
