sda interconnect
snow
snow Posts: 4,358
edited August 2006 in Wanted (WTB) Classifieds
looking for a polk interconnect cable for sda srs it has pin /blade connectors
Post edited by snow on
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2006
    Those never get sold here, traded occasionally for a AI-1 cable yes, you should make a cable, if your not into that, take a sub cable break the grounding ring off and plug her into the pin slot, it will work just fine, only use a common ground amp, which most are.
    RT1
  • snow
    snow Posts: 4,358
    edited August 2006
    RT1
    thanks was wishful thinking i guess huh:p
