Help
audiocrzy25
Have looked all over for the answer, could not find it. I have a Denon AVR-5805MK2 reciever. 170 watts by 10 channels.The front are biamped. 340 watts to my rti 12's. They sound great, but would i be better off getting a seprate amp?
Csi 5 center, rti 12 front, Fxi 5 rear, Rt55i back, psw 450, Onkyo tx sr 805b, Sony 400 dvd changer, Sony 50" Hdtv, 360 with HD dvd player, PS3
Post edited by audiocrzy25 on
No. Wait, yes. No, well it depends. Your pushing 340wpc already. How much more do you think you need? Or is it you think you've got enough power, it's just that the power isn't clean enough?
Will i get cleaner sound out of a amp.Csi 5 center, rti 12 front, Fxi 5 rear, Rt55i back, psw 450, Onkyo tx sr 805b, Sony 400 dvd changer, Sony 50" Hdtv, 360 with HD dvd player, PS3
Subjective I think.
I also think that particular Denon is enough for those speakers. Unless you have money to burn. That Denon must've cost a fortune, niceAVr. -
I picked it because i could biamp front two and power two centers, and four rti 8's. Thanks for the info.Csi 5 center, rti 12 front, Fxi 5 rear, Rt55i back, psw 450, Onkyo tx sr 805b, Sony 400 dvd changer, Sony 50" Hdtv, 360 with HD dvd player, PS3
