a few newb questions
alibabwish
alibabwish Posts: 12
edited August 2006 in Electronics
Im a little confused by some amp related issues. I have a vsx-515 pioneer home audio receiver connected to my monitor 40's for starters, but mainly what im intrested in is the difference between a home audio receivers amp versus i guess ill call it a dedicated amp that requires a pre-amp and stuff. for example, my vsx-515 says it can put out 110wpc(its a 6 channel) or 110wpc stereo which i usually run it on. I look at amps that put out 110wpc and they cost 500 or so dollars where as i payed 160 for my receiver. why can a receiver power 6 channells at the same power a regular amp that costs 3-4 times as much can. Also, whats the whole deal with a tube amp... ive seen em and they look cool but what benefits do they offer. As you could probally tell, im new to the audio wporld, but i really appreciate the sound of my new m40's over the **** sony speakers i originally bought and even the bose 301's i listened to at the store, im im told that the monitro 40's are only entry level speakers, i amost cannot fathom how much better the sound must get! But as i am a college student, i cannot afford that much now and hope to get the good stuff one day.
Post edited by alibabwish on
  • Joey_V
    Joey_V Posts: 8,600
    edited August 2006
    You have pm.
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited August 2006
    Receiver ratings are generally a bit generous with power ratings and don't quite have the control and abilitis of external amps.
    Tube amps use vaccuum tubes to amplify the signal rather than transisters. This keepes you music in the analog domain and, because of the nature of tubes, a more pleasing distortion pattern. Additionally, tubes clip differently and protect your speaker more than a SS amp. The down side is they are expenisive, expensive to upkeep, less power, less bass control.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • alibabwish
    edited August 2006
    would a external amp give clearer sound?
  • Joey_V
    Joey_V Posts: 8,600
    edited August 2006
    An external amp would give an overall better sound - not just clearer.
    How much are you looking to get the Monitor 40s for anyway?
  • jdhdiggs
    edited August 2006
    In a word yes. Here is my ranking of amps from worst to best
    Highs: AVR's, SS, Hybrids, Tubes
    Mids: AVR's, SS, Hybrids, Tubes
    Mid Bass: AVR's, SS, Tubes, Hybrids
    Bass: AVR's, Tubes, Hybrids, SS
    Granted this is just on persons opinion, but I think most would agree that AVR's typically provide the least quality of amplification to the speakers.
  • alibabwish
    edited August 2006
    I already have them, i payed 300 from circuit city, probally not the best price i could have gotten, but i wanted em right after i heard em and they were in my price range. Ill be a dorm this year and wont have much space, and im already brininging my sub, a sony i got for 150 that has 250w adviertised, my receiver, and the m40s. the next year after this year, i plan on getting an apartment, and with the more space i plan on completeing a 5.1 setup and the m40s will likely be my rears and maybe the m60s or m70s for fronts and a cs2 center.... or the cheaper path which would be m30's for rears m40s fronts and cs1 for center with my sony sub that ill eventually upgrade.....
  • alibabwish
    edited August 2006
    is a hybrid a mix between a tubes and ss
  • jdhdiggs
    edited August 2006
    Yup, kind of a best of both worlds/worst of both world's type thing.
    Just want to get you out of a little buyers remorse: AVR's aren't horrible, and I doubt anyone here dropped $5K on their first rig out of the gate. AVR's are great for what they are and are probably the best bang fot the buck item you could start with.
    Besides, if your in a dorm room, I would suggest having inexpensive stuff. First off, you don't know who your roommate/s is/are, and you don't know how drunk you, or they, will get. I'd rather barf into an AVR than get eletricuted doing the same on a tube amp.
  • Willow
    Willow Posts: 11,223
    edited August 2006
    Right cause a barf free zone maybe hard to maintain.
  • Joey_V
    Joey_V Posts: 8,600
    edited August 2006
    You may not want tubes in a dorm room....
  • AndyGwis
    AndyGwis Posts: 3,655
    edited August 2006
    If your receiver has pre-outs, and you are just running the two front speakers (and a sub), you should just be on the lookout for a deal on ANY two-channel amp off ebay or audiogon.
    Get one on the cheap, try it out for a while and see how it sounds. You can always sell it for what you bought it for down the road.
    Just for example, my first amp, the carver TFM-6, can be had for like $100 on ebay from time to time (although they often go for twice as much). Adcom GFA-535's are another really inexpensive way to get started in separates, probably $120-$150 if you get a good deal.
    Save up a bit of money and try one out if you're interested. Don't spend $500 on your first one, especially in a dorm.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • amulford
    amulford Posts: 5,020
    edited August 2006
    You definately don't want tubes in a dorm room...
  • jdhdiggs
    edited August 2006
    Following what Andy said... In the used market, you don't really lose much money. Typically, if you buy an amp for $100, you can sell it for $100
  • cfrizz
    cfrizz Posts: 13,415
    edited August 2006
    Welcome!
    I looked up your receiver, and you don't have preouts (except for a sub,) so you can't add a separate amplifier.
    Which is probably a good thing, since you are in a dorm.
  • dipiazza
    dipiazza Posts: 363
    edited August 2006
    I am in the dorm as well. If your using it for just listening to music in your small room, theres really no need to go seperates for Mon 40s. Its just not worth it, stick with your pioneer and upgrade later when you have a reason to.
    Good luck, Dorms suck for audio but what the heck us college kids gotta deal with it!!!
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Reciever: Pioneer VSX-D914
    HD-DVD Player: Toshiba HD-A2
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    Subwoofer: SVS 20-39PCi
    2CH Setup
    Integrated: Onix SP3 Tube
    CD Player: Sony CDP-CX355
    Speakers: Onix Strata Mini in PR Finish
    Signal Cable: Classic Speaker, Analog 1 IC
    Headphones
    Grado SR 60, Bang & Olufsen A8, Shure e3
    Other Stuff in Use
    Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
  • dipiazza
    dipiazza Posts: 363
    edited August 2006
    Where you dorming at?
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
  • alibabwish
    edited August 2006
  • dipiazza
    dipiazza Posts: 363
    edited August 2006
    Ewwwwwwwwwwwwww! GO TERPS!
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    2CH Setup
    Headphones
    Other Stuff in Use
