Dedicated Circuit
univera
univera Posts: 848
edited August 2006 in Electronics
I have a former general contractor coming out tomorrow to do various work, some of which is electrical in nature. He works for $25.00/hr. (because he wants to stay busy and out of the house and away from the wife...) Anyhow, he seems to understand the concept of a dedicated circuit. What exactly is recommended in this scenario: I will be having a flat panel put up in the next couple of weeks. My number one priority is a dedicated circuit for my audio gear. I know that it is important to isolate the digital domain as well. I would appreciate the ideal situation and then I will see what is realistic or attainable. I am assuming a seperate dedicated circuit for the AVR, cd/dvd and t.v.respectively is ideal? What voltage/amperage is needed at the box, particuarly for the audio end? Do I need to use special wire for best performance? I do plan on using a power condition as well, although I don't currently own one.
EDIT: After researching previous threads, I believe that one 20A circuit with a power conditioner will suffice. Is there any reason NOT to use a 20A when one has the opportunity? I will be using a Panamax 5100 ex which has 2 seperate high current outlet banks for amps only, so they are isolated and not subjected to current limiting. http://www.panamax.com/pdf/M5100EX_L548A.pdf
FYI: If you own an older Panamax 1000, it has a fatal flaw that will cause it to crap out at some point (like mine.) Panamax will sell you any, brand new, upgraded conditioner at 1/2 price plus shipping if you get an RMA and return the cord off the old unit. Its almost worth buying one off Ebay and returning it. Just tell them that it is displaying an "overvoltage" indication. I don't believe it even has to be malfunctioning to get the upgrade.
UNIVERA
Historic Charleston SC
2 Channel:
SDA-SRS's RDO tweets
Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
Anthem Pre 2L w/E.harmonix platinum matched 6H23's
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
DVD: Toshiba 3109 dual tray
Subs: Velodyne and M&K
T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
Conditioner: Panamax M5100EX
Master Bedroom Sony 40KDL-XBR3
"I love it when a plan comes together." Hannibal Smith, The A-Team
Post edited by univera on
  • Tony Jachyra
    Tony Jachyra Posts: 1
    edited August 2006
    A dedicated circuit is an attempt to isolate the circuit from any motor noise, which tends to cause havoc on sophisticated electronics. To size the circuit add up the amperage requirements of your equipment. Most equipment draws about an amp. I generally try to keep the total load on a circuit at about 75% of its rating. So 20 amp circuit would have no more than a 15 amp draw. I would defiantly invest in a power conditioner. I been using a Panamax on mine for many years and all my equipment is still in perfect working order. I still have the sales brochure from mine, which gives a lot information on what a power conditioner for home entertainment does. If you would like I can pdf it to you.
  • venomclan
    venomclan Posts: 2,467
    edited August 2006
    Hi Univera,
    I think that a dedicated circuit is the way to go and is my next upgrade. If you do get a power conditioner, be sure that it is capable of a 20 amp circuit. I have a Belkin PF60, and the manual says to only use with a 15 amp circuit. I called the company and verified also. So you may want to pick the right conditiner first. Through all my research, I think that 15 amps is enough for most systems. With all my gear running and 36" CRT, I only use 3.6 amps. Well within circuit limits. Check out htguide.com where the subject has been discussed a lot. Good luck.
    Venom
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited August 2006
    My own pref (the one I'll be using in the dedicated HT room) is:
    1 15 AMP Dedicated to the DVD/PRE/computer/tuner/whatever else not listed
    2 20 Amp circuits for amps /Subs
    1 15 Amp circuit for the projector/TV.
    This is serious overklill, but I'd rather have too much than too little.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • joeparaski
    joeparaski Posts: 1,865
    edited August 2006
    I agree on the overkill....in the new setup which is underway, I've wired the system with FOUR seperate 15 amp lines.
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • I-SIG
    I-SIG Posts: 2,243
    edited August 2006
    I'm planning on a trio of dedicated circuits. Two for the living room and one for the bedroom. All will be 20A capable. My problem is that I'm gonna have to crete a small sub-panel. I'm gonna wire it with at least #6Cu (which heavily down-rated for in-home residential use) as a feeder then split off two 20A circuits for the LR. I may only put a 40A single pole breaker in my main panel as I only have one spot remaining, but can upgrade it to a 60 in the future when I finally do a bedroom rig.
    I'm thinking to put my SVS and Parasound on one circuit and the rest on the other circuit and use the 15A circuit for fans, lamps, etc.
    The main advantage to these big circuits is lots of Cu to supply plenty of electrons and to keep voltage drop and flicker under control. At you panel, you should have 120/240VAC +/-5%.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • dorokusai
    dorokusai Posts: 25,577
    edited August 2006
    Do you have problems with the current circuit? Unless your popping a breaker, or have a large machine/motor running on that same line, a dedicated line will do nothing but make you feel better.
    It's a neat idea but if your power is dirty in the first place, it won't solve anything.
  • faster100
    faster100 Posts: 6,124
    edited August 2006
    it's kinda like 400 dollar outlets ? :D
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • univera
    univera Posts: 848
    edited August 2006
    DK, I don't have any apparent, known issues whatsoever. I do have a ceiling fan in the area, but I haven't checked to see if it is on the same breaker. I just gathered from reading posts that this was an advantage and would improve the noise floor. If you say I don't need it, I would listen. You seem to be very level headed in your approach. I will definitely be using a power conditioner for peace of mind and to clean up video/isolate amp section. FWIW, I haven't actually tested anything in terms of current, etc.
    UNIVERA
    2 Channel:
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
  • dorokusai
    edited August 2006
    Don't get me wrong, because if it's easy to do on your end....just do it. It's something you're not going to "lose" anything by doing.
    I went dedicated out of sheer boredom, but there was no perceived benefit. I know a couple folks who have also ran DC's and HAVE noticed a difference, and I respect their opinion greatly.
    If you can hear that ceiling fan turn on/run thru your speakers, when they are on(No signal, just on)....move it, if not....well, that's up to you.
  • jdhdiggs
    edited August 2006
    I agree with Doro, 99% of people don't need more than 5-10 Amps
    In my case it is easy to do (open spots in the panal, no walls yet...) and I'll have close to 3,800W of amps (7x400 + 1000) on the 2 20A circuits and I'd prefer to have the other high power item (PJ) on a seperate circuit from the processor/DVD/comp/anything else.
