center and surround for sda1
jerude
jerude Posts: 5
edited September 2006 in Vintage Speakers
i did a search and also posted on the speaker forum but got no help over there. i'm trying to build a 5.1 system with my sda1's which i think are the c version.(the connecting cable uses one pin and one blade) i was thinking of purchasing a csi5 for the center and rti4's for the rear. would these be a good match? if not what speakers would you recomend? thank you for any and all input.
Post edited by jerude on
  • bert26
    bert26 Posts: 320
    edited August 2006
    Hi Jerude -
    Welcome to the Forums!
    See if this link helps you out a bit http://www.polkaudio.com/education/showanswer.php?question_num=63
    I have used the CSi5 with both SDA1b's and SRS 2's to decent effect (currently using it with the SRS 2's). I believe your other choice is the LSiC, but I haven't had the chance to listen to that one. There should be some threads on CSi5 vs. LSiC if you search.
    My surrounds are Monitor 30's, and while they will suffice, I think they are one of the weaker links in my 5.1 system.
    Of course your mileage may very.
    Cheers!
    Chris
    HT Rig
    Polk SDA SRS 2.3tl - Anthem 2 SE
    Polk CSi5 - Adcom 555
    Polk Monitor 30 - HK DPR1005
    SVS PB12 ISD/2
    Denon DCD-1500II
    Sony SXRD 60"
    ShengYa CS-10
    Basement Rig
    Polk SDA SRS2
    Carver 1.5t
    Carver C2
    Technics SLD202
    Some Other Sony DVD/CDP
  • jerude
    jerude Posts: 5
    edited August 2006
    thanks for the welcome and the link.
  • Larry Chanin
    Larry Chanin Posts: 601
    edited August 2006
    Hi,
    As Chris mentions, the LSi series of speakers probably would also be a good match.
    Here's a link in which Matt Polk answered a similar question I had with regard to matching speakers to SDA-1Cs.
    Timbre Match for SD1-1Cs
    Larry
  • mhw58
    mhw58 Posts: 359
    edited August 2006
    I use the CS400I as my center channel and I think it is a good match for the SDA 1C's. Find some SDA2's for the rears and you'll have a perfect match
    in your left and right speakers.
    That's my system and I love it!
    Mike
    Fronts: SDA1C's
    Rears: SDA2's
    Center:CS400i
    Sub: PSW505
  • jerude
    jerude Posts: 5
    Mike
    thanks for the additional suggestion, neighbor. (im just outside of monterey, off of highway 68.) i will look into the cs400i.
