Now I've got it!...
Sax
Sax Posts: 70
edited August 2006 in 2 Channel Audio
With new drivers installed in my recently acquired RTA11's (up from Monitor 5b's I was using as computer speakers). An Adcom GFA-545II, a Teac PD-D700 5 disc changer, and a 70's Rega Planar 2 with Grace G-707 tonearm to round out the mix (so far). I present my first real hi-fi set up (JUST finished re-arranging the room and furniture to accomodate).
Best freakin sounds I've ever heard, yet conceptually I KNOW it'll only get better from here. I've still yet to hear Tubes. I have a $45 Audio Technica cartridge. There are many other areas for improvement. But I present my Hi-Fi room version 1.0. ( I say 1.0 because its the first set up of enough good components to call the entire thing a hi-fi system ) (but then again it may just be the programmer in me).
I spent a lot of time on set up to get the best out of what I do have. The turntable is level, new belt installed, just cleaned and re-lubed my platter bearing. (I used 80w/90 Hypoid Gear Oil, aka EP80. I read that it was essentially the same as offical bearing lube). VTA still needs to be fine tuned but I need to get a spacer to really do that...otherwise the cartridge has been meticulously adjusted. I took great care to not have any power cables parallel to any signal paths, etc.
So anyhow, without further adue, I present the photographic evidence :)
now, keep in mind, I got this coming sometime later this week or hopefully early next week at the latest (its already ordered)
Monitor 5b
RTA 11T
Rega Planar 2 (1970's)
Adcom GFA-545II
Post edited by Sax on
  • Sax
    Sax Posts: 70
    edited August 2006
    heck with upgrades, I just realized... I still need to break IN my new drivers! lol. These are gonna sound nice, I just know it...but I can somehow hear that they do indeed still need to break in... (the new drivers).
    What amazed me though is what the adcom did to my Monitor 5b's... they sound like a whole new speaker.
    edit: sorry for double post, I had though I had used the edit button when it was really just the quick reply.
    Monitor 5b
    RTA 11T
    Adcom GFA-545II
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited August 2006
    Lookin' good! Enjoy the music.
  • steveinaz
    steveinaz Posts: 19,538
    edited August 2006
    Cool vintage flavor setup. I like it.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited August 2006
    Neato!
    billbillw Posts: 6,842
    edited August 2006
    Sax,
    I'm not sure what Rega recommends, but you may want to re-think the use of gearlube for your turntable bearing. Everything I've read points towards using thin oil that will not break down over time. In other words, thin (5w) synthetic motor oil or sewing machine oil. You don't want thick stuff gumming up your bearing. Gear lube is usally meant for high temp/high stress environments like car transmissions or industrial gearboxes. Otherwise, nice start to your system.
    For rig details, see my profile. Nothing here anymore...
  • danger boy
    danger boy Posts: 15,722
    edited August 2006
    very nice looking. those RTA 11's are taller than i thought they were. enjoy
    PolkFest 2012, who's going>?
  • Sax
    Sax Posts: 70
    edited August 2006
    I love them!.
    billbillw, I have researched it thoroughly and in several sources found it recommended from rega directly specifically Comma Hypoid EP80, Castrol EPX80w/90 or Shell Spirax EP90 to be used as replacement bearing lubes. The thicker oil also acts as acoustical damping to the bearing and shaft and these are closest to the official bearing oil provided by rega, as I have found. Don't get me wrong I'm not disputing you, this is actually still a matter of debate as I don't have any *official* sources, and if you have further information I'd research further and appreciate your input.
    ALSO....
    my last two drivers came today. I now have two RTA-11t's that are better than new. All-new drivers with RD0 tweeters. oh yeah.
    and then also, the audio gods were smiling upon me, as it was only last night that I re-arranged my room in the above pics, when my audio rack came today. I ordered it sunday.... apparently it shipped out of LA and I live in SD. What luck!
    edit: I also got some really good RCA's today then, since I now have all my drivers and the cherry stand, I got it all set-up really good while I was at it.
    So now, updated pics!
    Monitor 5b
    RTA 11T
    Adcom GFA-545II
    SCompRacer Posts: 8,511
    edited August 2006
    Sax wrote:
    I love them!.
    I'll second that. Two 'dollops' IIRC, which means really big drops.
    Nice setup. Njoy!
  • GuitarheadCA
    GuitarheadCA Posts: 400
    edited August 2006
    Sax,
    How is the new VTI stand? I'm about to order the 404, which is only slightly different than yours (which you probably know) and it'd be nice to have an opinion about the quality. Also where did you get it from - racksandstands? Standsandmounts? It looks like you got the Cherry/Black/Gold - How's it look?
    Thanks,
    Peter
  • Sax
    Sax Posts: 70
    edited August 2006
    oh, its cherry/black/silver. the lighting may be giving a gold effect but look closer its the silver finish.
    Build quality... I'm floored. Its solid... I stacked the shelves up and sat on the top. I used to walk into the room and my needle would skip (we have bad floors) and it elimited that. I give this an A+ in my book. I've looked at other stands and nothing in this price range even touches it I feel. To get this quality you normally have to pay a lot more it seems.... so in summary I'm a huge VTI fan now. Definitely.
    I got it from racksandstands.com, to answer your other question.
    How's it look? Dead sexy! :)
    Monitor 5b
    RTA 11T
    Adcom GFA-545II
    edited August 2006
    Well, like I said, I wasn't sure what Rega recommended. Maybe their bearing is a little different design from some of the others I've had. I wouldn't worry about it.
    Nice setup. Njoy!
