Windows Help! Task Bar
venomclan
Hi Guys,
For some reason, the task bar (start button bar?) that is always at the bottom of the screen is now along the right side of my monitor and driving me nuts. Is there a way to fix this? Thanks in advance. I is a computer student.
Venom
Venom
yep, just click in a blank area and drag it where you want it. if it doesnt move, right click and make sure there isn't a check in the lock option
it shouldn't be locked, but ya, it's just a drag and then put the bar to the bottom of the screen. It won't fluidly move with your mouse, so just click in a blank area, move towards the bottom, then it will suddenly pop to the new location.comment comment comment comment. bitchy.
That did it. Thanks guys. I appreciate it. I am now putting my shotgun back in the drawer and the E Machine is safe yet again.
Venom
