advice on an amp!!
Systems
hey everyone,
i need some feed back on an amplifer. as of now i am thinking about 2 different ones: a JL 300/4 (75X4 RMS) or a blaupunkt PA4100 (100X4 RMS). which one would be best for 2 pairs of polk DX components?! i think my plans are to run the front normally and run the back in tri-mode so i can use a sub....either that or put the back speakers on the reciever and bridge the rear channels... so what do u think? the jl is 75X4 at 11.5-14.14 V and the blaupunkt is 100X4 at 13.8 V, and as of now i have 11.8 V..... everyone give me feed back! thanks!!!
Testing
Testing
Testing
Testing
Testing
1) the JL amp will sound soooo much better/cleaner
2) The JL amp is not over-rated like the other amp
3) how can you compare the two amps?
IF JL did one thing right..IT was thier amp line. :cool: -
Josh,
If you are open to other suggestions I would recommend that you also look into the UC Acoustics amps. They are good quality, have a 3-year warranty and are not expensive. If you are set on a JL or another brand that's alright too, I just thought I'd give you another alternative.
Mike -
That should have read, "US Acoustics"
Mike
