Sub Placement
flr057
flr057 Posts: 20
I just bought a PSW 505 and have been experimenting with different positions in my HT room.
If I place the sub in a corner (as seems to be recommended as an optimum place), should the front firing sub face the corner?
Same question if I were to put it up against a wall (about 10" out)?
Yamaha RX-V995
HK PA 5800
Klipsch KLF-10 (front)
Klipsch Academy (center)
Polk Rt- (rears)
SVS - PC12- NSD
Post edited by flr057 on
  • tecmo04
    tecmo04 Posts: 421
    edited August 2006
    face the sub outward. corner is normaly going to give u the loudest result, but it also can be very "boomy". but keep experimenting. i guess what im trying to say is do what sounds right to you
  • Andrew2112
    Andrew2112 Posts: 59
    edited August 2006
    Tecmo is right, the corner placement will give the loudest and boomiest sound. That's is where I have mine and it took me quite a bit of tweaking and testing until I got it "right".
    BTW the front should be facing the room.
  • ronnie
    ronnie Posts: 150
    edited August 2006
    this sub is a rearfiring sub. the slot port should be facing the wall. the closer to the wall the boomier the sub will sound ....depending on your taste i would play around with it and once you found the sweet spot.....ENJOY
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Yamaha CD685 cd changer
    Yamaha Dvd c950 dvd changer
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    Polk RTi6 (surround and surround back)
    Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
    WindyWillys cooling fan (works great)
    Mitsubishi 52in big screen
    blue jeans cables
    AR interconnects
  • Leeep
    Leeep Posts: 4
    edited August 2006
    One thing I've heard and always tried to stick to; don't put your sub the same distance from two walls. Something about "standing waves" it usually works for me. In my examle, it's about 3" from the front wall and 8" from the side wall.
    I just had to move it literally 1-2" to acomodate my new mains and I swear the bass sounds way too boomy now.
